b18c1 wont hit vtec
Old Apr 1, 2014 | 02:43 PM
mydb2whoopsu's Avatar
Default b18c1 wont hit vtec
So I recently swapped a b18c1 into my integra its both gsr block and head. Code 22 pops up when I get to full temp . Code 22 is vtec pressure switch . I have replaced the switch. I have checked all wiring from solenoid to ecu no break inwiring all grounds are good solenoid work properly(heard clicking when I hooked it up to battery.) The head was running ls vtec before I got it . so was there anything that could have been altered or taken out for ls vtec to work? Please give any suggestions they would be appreciated. Thanks
Old Apr 1, 2014 | 02:59 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: b18c1 wont hit vtec
Yes - you need to pull the 1/8" plug in the cylinder head for VTEC to work. This is assuming the LS/VTEC was done properly to begin with.
Old Apr 1, 2014 | 04:18 PM
What is used to to plug it
Old Apr 1, 2014 | 05:50 PM
Read that wrong . Hopefully that solves my problem thanks
Old Apr 1, 2014 | 07:39 PM
DO IT ON ALL FOURS
Just in case, usually it is done with a flush pipe plug that you use an allen wrench to remove the plug. You must REMOVE the plug to allow oil to flow to the VTEC solenoid. On a LS/VTEC setup an external line is used to supply the head with oil for VTEC activation.
dai-18t
Feb 18, 2008 11:15 AM
slo_crx
Oct 6, 2006 11:26 AM
HUYNH
Aug 5, 2006 03:43 PM
Trooper
Nov 17, 2003 07:25 PM
b18c-93
Jan 8, 2002 12:37 PM
