idle randomly drops when warm, getting ckp code
Old Mar 30, 2014 | 05:20 PM
em1goesbwah's Avatar
Default b16a idle drops randomly when warm code 4 ckp thrown
Hi forum. Ive been having this problem all winter and after a few unsuccessful attempts to fix it I am going to post again in hopes that somebody can help me out. I own a 1998 civic si (Canada) with a JDM b16 sir2 w/ p30 ecu.
The issue is that when the car gets up to full operating temp and idle is low (700-800) the idle will suddenly drop to like 200 then come back up and the engine will sound weird. The CEL comes on as #4- crankshaft position sensor. I am also getting electrical load detector.
What I've done : timing belt, timing tensioner, valve adjustment, wires, cap rotor and plugs. Haven't had a timing light on it yet but the dizzy very slightly advanced.. wouldn't expect it to cause this? Can anybody help me! Thanks.
Old Mar 30, 2014 | 10:06 PM
Default Re: idle randomly drops when warm, getting ckp code
bump.. really need some help on this! thanks
Old Mar 30, 2014 | 10:19 PM
fleabag's Avatar
Loose wiring to the connector that goes to distributor? I don't know but definitely could be a distributor issue, incompatible with your setup, crappy one/broken, or something.
I mean it would be a good idea to inspect and clean up all your electrical grounds to your engine, making sure connections on both ends are shiny.
Oh read this thread here: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/where-crank-position-sensor-2796258/
you should do better searching... Try this in google.com
CKF sensor honda civic site:honda-tech.com
That way you do a google search of honda-tech.com for the search terms.
Old Mar 30, 2014 | 10:28 PM
P-M-B,93EXsedan's Avatar
Thanks fleabag. Maybe now when I try to search this site ill actually find what I'm looking for instead of interesting bs'ing instead. I need to stop getting distracted
Old Mar 30, 2014 | 10:31 PM
I will check out my grounds. I appreciate the google tip! I did this a while back :
Measure the resistance between sensor terminals B & F (ECU terminals B15 BLU/GRN wire & B16 BLU/YEL wire)
If the resistance is not between 350Ω & 700Ω replace the distributor.
I got a result of 342, however there was no continuity on both terminals to body ground. Does this mean that my distributor is bad?
Old Mar 31, 2014 | 11:02 PM
Bump.. Is my distributor gone for sure?
Old Mar 31, 2014 | 11:44 PM
fleabag's Avatar
only one way to find out but it would appear from your testing that indeed your distributor is bad! Since the ohms are just out of range, it explains why the car runs at all with a check engine code vs. not running at all.
Old Apr 2, 2014 | 10:56 PM
Makes sense, but it doesn't do it all the time. The cel will only come on when it drops in revs and almost seems like the ecu goes into a different mode. The whole car runs different and it resets when I restart the car.
Old Apr 3, 2014 | 04:36 AM
Former User's Avatar
Fix code 4 before you do anything else.
As for code 20, check whether fuse 15 is blown.
Old Apr 3, 2014 | 05:13 PM
I checked fuse 15 and it looks fine. My symptoms continue to get worse, always throwing ckp code and limiting my revs / power.
Old Apr 4, 2014 | 12:08 AM
fleabag's Avatar
What do you want us to do now? The solution is pretty obvious, no?
Old Apr 4, 2014 | 10:49 AM
I'm just wanting to be sure. Dizzy, right?
Old Apr 4, 2014 | 12:49 PM
fleabag's Avatar
Yes, I would say with great confidence that it is the distributor considering the fact that you even went as far as to fully diagnose it since the spec's are out of range. Seems pretty definitive to me.
Old Apr 9, 2014 | 09:07 PM
So I replaced the distributor.. unfortunately it wasn't the culprit... 380$ later. It was the harness between the dizzy plugs and main harness plug? ( Y shaped). Anyway, when I was playing with the dizzy I flicked the plug when it was running normal and sure enough it started running weird... wiggled some more and it stalled out and died. Took it apart, there was corrosion on the pins that go into the main harness so cleaned those off, reinstalled harness and sure enough it ran like it was supposed to. Played with wires and no change. Moral of story.. check the basics! Thanks anyway.
Old Apr 9, 2014 | 09:08 PM
Originally Posted by em1goesbwah
Moral of story...
...invest in a multimeter.
Old Apr 9, 2014 | 10:56 PM
fleabag's Avatar
DUDE....
Gator417
Aug 19, 2015 08:41 AM
CCFM563
Oct 21, 2014 04:12 PM
trevek10
May 16, 2011 03:07 PM
bassysingh
Oct 17, 2005 10:02 AM
