Another speedometer problem. Replaced cluster and vss
Old Mar 12, 2014 | 03:03 AM
Sharpen047's Avatar
Default Another speedometer problem. Replaced cluster and vss
Just as the title says, speedo doesn't work. Worked 23 miles of the 350 on the last tank of gas.
Car is a 2000 dx
Speedometer indicates 19 mph as soon as I turn the key to the "on" position.
Wobbles from about 14-26 at anything below 19(wobbles faster the faster I go).
Anything over 19 it indicates 19 with no wobble.
Brand new vss, unused as we'll.
Put in a second cluster from a 2000 ex, same thing.
This to me sounds like a wiring problem, like the cluster is getting signal but not a ground?
I've seen the CSB on the harness hitting the rear intake manifold bracket but don't see anything rubbed through but I put some electrical tape there to make sure-no change.
I know the connectors tend to corrode but mine looks fine. It I also cleaned with contact cleaner to be sure. Again no change.
If anyone has any ideas on how to test the harness I'm all ears.
Oh and the car is a manual so the Ecu won't make the car act funny.
Thanks in adance.
Old Mar 13, 2014 | 07:28 PM
that_boy_sammy's Avatar
Default Re: Another speedometer problem. Replaced cluster and vss
Is it auto or manual? Are you getting a Rpm Signal?
Old Mar 13, 2014 | 10:05 PM
P-M-B,93EXsedan's Avatar
My girlfriend's Kia has the same deal. Sometimes when I wiggle the pigtail for the speed sensor it works again, today when i tried while I flushed her trans it didnt tho. I'm pretty sure I need a new connector for hers, the original speed sensor left a contact in it and I had to pick it out and well I fucked it up a lil. I'm gonna open the harness a little and run new wires to the new connector when i find one.
maybe you should check there, if you can shake the wires leading to the Speedo sensor and that creates a difference then that would be where the problem is.
Old Mar 14, 2014 | 02:17 AM
Sharpen047's Avatar
Manual, with a working tach .
I've tried wiggling the connector. It does seem loose but I've had friends sit inside while I clamp alligator clips to the pins. Even unplugged the speedo say 19. Leading me to a harness short.
Thanks
Old Mar 14, 2014 | 04:21 AM
Grape Ape Guy's Avatar
i thought my vss was bad... hooked a scan gauge 2 up and it gets signal.... when the dash does work its within 5mph so I know my is wiring at dash or the dash itself
Old Mar 16, 2014 | 06:41 PM
Sharpen047's Avatar
Alright I'll do that. Any idea what color the wires change from/to between vss plug and dash? I'll try to find an obd scanner that reads mph
Old Mar 18, 2014 | 02:52 AM
Sharpen047's Avatar
Alright no luck yet with the scanner but, if Ecu wasn't getting a signal wouldn't it throw a cel?
would It also be safe to think since there is no cel that the problem is in the dash somewhere? I know the lights are never 100% accurate but could be a good start right?
blinger
11
Mar 26, 2024 08:08 PM
MilanoCpe
15
Apr 20, 2023 10:42 AM
SpoonfedCivic
18
Jan 30, 2011 03:33 PM
mihaylm
Aug 16, 2005 11:37 AM
