Transmission & Drivetrain Gearboxes, Differentials, Clutches
Hard Shifting, Can't Downshift, Jerks with clutch pushed in cruising in gear
Old Mar 10, 2014 | 06:07 PM
2000blksi's Avatar
Default Hard Shifting, Can't Downshift, Jerks with clutch pushed in cruising in gear
Okay I have a 00 si em1 with a s4c hydro tranny, problem started a few days ago it was getting hard to shift into all gears up or down at all speeds. Thinking syncros, then this morning just before i got to work when i would push in the clutch but leave the tranny in gear coasting it would jerk a lil bit then hit real hard. Then when I left from work it was still doing the jerking thing unless i pulled it out of gear when coasting down or stopping, also it won't downshift i have to come to a complete stop then go from first shifting fine all the way up.
Question is what is wrong with my tranny??????
Old Mar 10, 2014 | 06:30 PM
F22Master's Avatar
Default Re: Hard Shifting, Can't Downshift, Jerks with clutch pushed in cruising in gear
Sounds like a clutch issue to me.
Old Mar 10, 2014 | 09:02 PM
Mista Bone's Avatar
D Tranny Guru
Clutch disc spit out a spring. Common on B series. I bet it shifts fine with the engine off.
Old Mar 11, 2014 | 08:29 AM
2000blksi's Avatar
Yeah it shifts like butter, could it be the slave or master cylinder or just a spring you think.
Old Mar 11, 2014 | 08:36 AM
Freemananana's Avatar
Probably lost a spring. It's happened to me on a car before. It's real tough to push the clutch down while it's running. Can you remove the inspection plate for the clutch and maybe spin the crank in gear or something? You may be able to see a spring flapping around in there. I know when I dropped my trans 2 of the 4 springs were bouncing around and the clutch disc was displeased.
Old Mar 11, 2014 | 09:05 AM
2000blksi's Avatar
clutch pushes down fine same as always, I am going to try and get the inspection plate off tonight.
AlAddiN|502
Apr 8, 2009 06:31 PM
t0mmysays
Jul 6, 2006 10:21 PM
mchuang
Mar 9, 2004 05:14 AM
reaction360
Oct 27, 2003 01:32 PM
eg_hybrid
Oct 6, 2001 08:27 AM
