1996 Civic timing question
Old Feb 3, 2014 | 03:23 PM
raider1qaz's Avatar
Icon3 1996 Civic timing question
Well when i time my car with the timing marks i do the cam first then the crank and i put the pointer on the red mark but when i put the belt on and put the cam the right way the timing on the bottom is way off,is this suppose to happen??? the cam says "up" is facing 12oclock but on the bottom pointer the mark is like a inch to the right(red mark on picture is where the pointer is pointing to)
Old Feb 3, 2014 | 03:25 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: 1996 Civic timing question
The "pointer" is supposed to go to the white mark when installing a timing belt. The red mark is your setting your ignition timing.
Old Feb 3, 2014 | 03:29 PM
raider1qaz's Avatar
it is?so when i time the belt i use the white mark/?
Old Feb 3, 2014 | 03:30 PM
raider1qaz's Avatar
when the "UP" is at 12oclock the pointer is suppose to be pointing at the white markl?
Old Feb 3, 2014 | 04:12 PM
NotARaCist's Avatar
Yes, when you set mechanical timing, it is. When you set ignition timing (motor warm and running, with a timing light, by twisting the distributor, you use the red mark.
Old Feb 3, 2014 | 06:22 PM
raider1qaz's Avatar
thank you very much
Old Feb 3, 2014 | 07:45 PM
kwae's Avatar
Awesome timing belt video
KeithsDAteg
Nov 29, 2009 05:32 PM
D16SohcVtec
Apr 10, 2009 11:35 PM
supabang
Aug 3, 2007 10:54 PM
getdowndoyou
Mar 14, 2007 08:14 PM
joestud
Jul 9, 2002 11:49 PM
