b16 locked up
Old Dec 11, 2013 | 03:34 PM
DatEk9Reaper's Avatar
Default b16 locked up
alright guys i need help with this one i have a b16a and my engine locked up i took the head off and everything is in good condition just need to change my head gasket tried to turn the engine over manually and nuffin what could be the problem ??
Old Dec 11, 2013 | 03:37 PM
B(eighteen)C's Avatar
Default Re: b16 locked up
was it seized before or after the headgasket was change?
is your car in gear....?
Old Dec 11, 2013 | 03:38 PM
it seized before changing the gasket
and yea i was driving and it just cut off on me
Old Dec 11, 2013 | 03:46 PM
24TEN's Avatar
PHANTOM MENACE
Also, maybe you need to go a step further and pull the transmission and/or drop the oil pan to see if there is anything physically preventing the rotating assembly from spinning.
Old Dec 11, 2013 | 03:53 PM
i was thinking that too hoping not to have to do it but probly will have too dis weekend ill keep you guys posted of what happens i know i dont have anything wrong with the pistons or rods cause theirs no holes in the block
Old Dec 11, 2013 | 05:07 PM
carlos8's Avatar
You can have a lock rotating Assy. without holes!!!
This is called roll a bearing. (enrollar un bearing)
Old Dec 11, 2013 | 05:39 PM
24TEN's Avatar
PHANTOM MENACE
^Spun bearing I think is the term we're used to in the US but the translation is good enough
Old Dec 11, 2013 | 05:47 PM
B_Swapped93's Avatar
have you actually tried starting it tho ? what happens if so
Old Dec 11, 2013 | 05:54 PM
carlos8's Avatar
He already remove the head.
24ten, thanks some terms are really different in Spanish, but yes I've heard the word spun, for rod bearings fails.
Old Dec 11, 2013 | 05:57 PM
yes I know but he just jumped to that vs actually to diagnose it properly, which I why I find it hard to believe that it ran fine prior to the hg replacement then it "locks up" all of a sudden.
Old Dec 11, 2013 | 06:02 PM
carlos8's Avatar
yes at first I think the same then read post #3
It seized before H.G. change.
Old Dec 11, 2013 | 06:07 PM
yea i had tried starting it up and it just made some weird *** like buzzing sound i did that before i took the head off; but i knew i already knew i needed a new head gasket so that had to come off either way im just tryin figger out what it might be before i put the head back on and do the time belt etc. to just have to take the head back off
Old Dec 11, 2013 | 06:56 PM
btw it wouldnt start back up after getting my alternator changed out but shouldnt i still be able to turn the block over manually before getting the timing belt retimed ?? and when i drained the oil and ani freeze they were both clean so their was no water that got into it or any antifreeze or oil mixing i checked all that time of stuff before taken the head off sorry i wasnt clearer about that earlier that i didnt just dive into this problem with out checking for smaller things first
lilshady6796
May 23, 2009 11:21 AM
rc90hatch
Jan 10, 2006 05:49 PM
trecool44
17
Dec 5, 2005 05:16 PM
BoostedAcura
Dec 24, 2004 05:36 PM
sykotik sol
Nov 17, 2004 03:08 PM
