jdm D16Y8 with US parts = idle problem?
So my motor failed. A family friend offered to use his discount and experience as a mechanic to buy an imported motor and install it for me. Except he has never worked on a honda before... So now that the motor is in there are some problems. I don't want to immediately point my finger at him if there may be another explanation, some personal experience would be much appreciated :-)
1- the idle is facked up. Sits between 1200-1400 and just jumps around there. Plus when driving the motor lurches whenever you let off out push down on the gas. Through all rpms. The only code being thrown is for the IACV but I haven't gotten time to clean it myself yet.
2- he did the timing "by ear" because he is a "professional". But he said is not perfect because the idle is not right.
3- it sounds like the throw out bearing is bad, but he changed the clutch. Push the clutch in, it's quiet, let it off and there is a constant "ssshhhhhhh" sound.
4-THE TRANNY IS LOUD!! And rough. Is this at all normal for japanese transmissions? I can feel lots of vibration and what seems like generally unhealthy stuff going on via the shift **** and it makes me weary. Both the motor and tranny have a 90 day warranty.
I went to clean the IACV just now and noticed it is way different than the USDM part that was on my old Y8. The motor came with the Japanese harness but it is plugged into my American ECU. Could this be a problem?
It drives fine (minus the problems above) and I was really surprised how much stronger VTEC is on this motor. But I'm not pleased with these results as you can imagine. Any advice from those of you who have experience with japanese motors would be great!
*****************UPDATE***************
instead of reading everything here are my new facts.
turns out he didn't buy a D16Y8 like he said, it is a D16A.
which would explain the "extra sensors" thing. Running the car with the IACV un plugged changes nothing, which means it is not communicating with my Y8 ecu. So now I'm at a cross roads. I have two options, either switch over the entire wire harness and intake manifold which I have in my garage (the dizzy too?) or try to get my hands on some sort of computer system than will run this engine cleanly.
will ANY piggy back system be able to communicate with the japanese IACV via my Y8 ecu? or will i still run into the same problem of my ecu is looking for one sensor and it is getting info from another? Is my only option either get the stock D16A ecu or upgrade to a stand alone system? I emailed greddy about the E-manage Ultimate to see if it will work...but haven't heard back from them yet.
remember my motor is the JDM D16A SOHC VTEC and its OBDII. So if I were going to tune on anything other than a piggy back I would have to get a jumper harness too.
Fix your IACV - that's what's causing your hunting idle.
He's correct. You can't properly set ignition timing with a fucked up idle.
Foot off clutch noise means it's your input shaft bearing, not your throwout bearing. That's inside the transmission. Combine that with #4, and it sounds like you need a new transmission. No, that noise and grinding and feeling **** on the shift **** is not normal.
Did you use the OEM wiring harness, or the harness that came with it?
WOw sounds like you got your self a BAD situation
first things first dont drive the car park it. second find someone who knows what the hell their doing ask around get different opinions tell you find the right guy, your motors in the worst parts over now find someone who knows what the heck he is doing good luck report back let us know whats going on
That was what I was suspecting...but wanted a second opinion, thank you. And no I did not use the stock harness. He used the harness that came with the motor but it's still using my ECU. He mentioned there was some extra sensors?? But didn't specify where. Which doesn't make sense since its the harness that came with the facking motor...
I'm taking the car back to him. Grand total is 3500 including the price of the motor and tranny. So I'd say not too terribly bad...but still not close to cheap enough to leave me picking up the pieces like this. Thanks for the replies!!
Some points of note:
- JDM D16Y8s or equivalents don't exist
- You can't use the JDM harness in a USDM car without having a bunch of issues.
- The input shaft bearing (or one of the other 4 bearings in the trans) is bad, which is further indicated in your point about the trans being rough.
- The idle problem you're having is from trying to use a 3 wire rotary style IACV with an ECU looking for a 2 wire linear IACV
[*]JDM D16Y8s or equivalents don't exist[*]You can't use the JDM harness in a USDM car without having a bunch of issues.[*]The input shaft bearing (or one of the other 4 bearings in the trans) is bad, which is further indicated in your point about the trans being rough.[*]The idle problem you're having is from trying to use a 3 wire rotary style IACV with an ECU looking for a 2 wire linear IACV
What you can do is swap over your original intake manifold and throttlebody along with the engine harness and it should solve your idle issues. The trans either needs to come apart or if it's under warranty exchanged.
It is actually a D16A. And yes the IACV are totally different. I tried running the car with the IACV unplugged and it made no difference. I just called the guy and he said he won't do it, at least not unless I pay him for all the labor...I don't like this guy. So I guess I get to swap the harness on my new motor myself. Do you think getting an ecu for my ACTUAL motor would solve anything? It is the complete motor and harness, so the only American part left is the computer. Just a thought, instead of using my old *** manifold and swapping everything around/potentially breaking something due to lack of experience... I can't think of anything on the car that would interfere with the new ecu. But I could be wrong.
As far as the transmission I will go to the supplier to try and get it replaced since it is clearly fucked. Thank you again!
if it is possible I would like to keep the intake manifold and wire harness all together. simply because my old parts have 230,000 miles on them and these have around 40,000. injectors, wiring clips, hoses etc. I updated my original post but I'll ask again. If I am having this communication issue between ecu and the IACV now, is there any piggy back system that can help it? I'm thinking if I wanted to do piggy back I would first have to buy the D16A ecu and then work from there, right? otherwise it has to be stand alone or switch everything over to the old parts, which I'm worried won't last nearly as long.
Any chance you can get a couple of pics of the engine? D16A came in a few variations, but I'm pretty sure you have the OBD2 version.
Here is a quick video I took of the idle bouncing and just a close up on the motor. Sorry for the poor lighting. Would and OBDII motor even run if plugged into the ecu for my Y8? The only code it's throwing is the IACV.
You can also drill and tap the back of the new intake manifold to accept a 5 speed Y8 IACV but you'll most likely have to remove the manifold to do it, you wont really have enough room in the car without a right angle drill, even then it's pretty easy to drill the holes crooked when you can't really see what you're doing.
Personally, if it was mine I'd swap the manifold, throttlebody and wiring harness over from the original engine. This way everything works, the ECU will communicate with a scan tool (important for emissions, or even just if you're selling the car and someone wants to scan it (I always take a scanner with me when I'm looking at a vehicle) Make sure you order gaskets from Honda (don't use felpro here, they use a thick graphite gasket that fits like crap, the real gasket is a nice paper version)
Then you can sell the new manifold and throttlebody to someone with a D16Y7 as it's a bolt on upgrade for them (the Y7 also uses the 3 wire IACV but it's got a weird upturned manifold) List it as an automatic D16Y8 manifold as it's exactly the same as one and people are more familiar with that terminology.
Btw, I can hear that bearing, it sounds terrible.
Have him swap the intake manifold. How did he do the mechanical timing? All timing marks have to be aligned on the crank and cam.
By rotating the distributor slightly I believe. Dunno why he even messed with it in the first place since it should have been fine. He didn't touch the motor...
Yes, it will run fine other than the IACV code and bouncing idle.
I know that's what I'm saying, it has a stock cam gear and he didn't change the timing belt or anything. so unless he just decided to advance it by a tooth on the belt for no good reason...he only messed with the ignition.
On that note, if you didn't replace the timing belt when you put the engine in you might want to do that. I always put a new timing belt on before I drop an engine in unless I know for a fact it's nowhere near due for replacement.
Yeah I was dreading doing that too. I pretty much got raped on this whole deal. Almost 4,000 bucks to simply install a motor. That still needs a fair share of work done. FML
GUESS WHAT!!! the head gasket, oil pan seal and main seal are all leaking. head gasket is the worst and there is oil pouring into my coolant... back to the beginning.
My brother's best friend has been the master technician at the local Honda dealership for 4 years and he came over to lend a hand. As we were swapping the harness and intake manifold we asked him to look at the whole swap and point out any and all mistakes of my "mechanic" and then write out a price quote of what it should have been. He said it would have been cheaper to have the dealership do the swap as far as labor cost. I'm going back to the motor supplier to see about just getting all my money back and giving their **** motor and tranny back. I'm taking all the receipts and my quote from the master tech and get my money back from that crook. The way I see it I have to redo EVERY SINGLE THING all over again. and since he won't do it he can pay me back for doing his job for him. if he refuses I'm taking him to small claims court.
There are so many problems with this car and many many hours of work that need to go into it before it is anywhere near reliable. at this point I'm just looking for a new car and I'll try to get as much money back from all this bullshit as I can. FACK!
I'm not sure what kind of shape the rest of the car is in but with a good engine and trans the car should work well and provide reliable service for a long time.
Motor was 700, trans was 500. The total bill was 3600. There wasn't any extra parts or services done at all. He simply dropped the motor in without touching it and plugged it in. Thats it.
The parts dealer won't take the engine back and I'm having to really argue with them over the warranty. It was done a week ago and has a 90 day warranty.
Other than the drive train it needs new brakes all around, New tires, tie rod ends, power steering pump, cruise control unit, stereo and wiring needs to be completely redone, two struts are blown, passenger side window doesn't roll down(regulator), no AC piping or components, windshield is cracked to ****, the welds on the front cross member have separated from hitting speed bumps. 2-3,000 in body work to get it straight again.
It was beat up when I bought it and definitely hasn't gotten any better. I can't do all this stuff in any sort of decent time frame plus I work two jobs and need my car all day every day.
