Boost gauge not showing boost
I have an autometer boost gauge on a crx b20 turbo, it shows about 20 vac at idle, but when I press the gas too the floor it goes straight to 0, I can hear the turbo spooling and everything can someone help, I tested the gauge and it works fine
Where do you have the sensor connected, if I had to guess I'd say in the brake booster line after the check valve... which is why it shows vacuum and not boost
You are either sitting still and revving the engine and it won't build boost unless you have anti lag setup OR you've got a boost leak. Either way it sounds like this is and FMU or basemap setup ready to go kaboom then the question will arrise why did my motor blow.
lol
Whether I'm going or staying still it moves with the gas pedal, no gas=20 little gas it stars going to ten then full throttle it goes straight to 0, I'm not sure if it is hooked up to the right vacum hose. So which hose to I connect it to?
the only thing you cant run off the fpr T is a blow off valve. boost gauge will work fine. if the car was put together properly youll hear and feel the spool AND see some positive pressure on the gauge. sounds like you got an NA car lol
b18tdelsol
May 18, 2002 11:46 AM
