Civic EK4 SiR transmission problem
hello
i have JDM EK4 Civic SiR
it was with an auto transmission
a week ago i converted this car to manual
everything is working fine but this gearbox have some problems
sometimes i cant select second gear
when i shift to second (no matter from first or from third) it seems now gear is selected but when i release clutch, car is not in second gear. its in neutral but shifter is in second gear`s position. all other gears are selected normally. at any revs. also when shifting to second gear rapidly in high revs it produces grinding or scratching sounds like broken synchros
can anyone tell my reason for that treatment?
what parts in gearbox should be replaced to fix that issue?
i am going to replace all synchros anyway but i think this is different problem
Did you open the new trans and see if it was any good? Might just be a crap trans with a busted 2nd. Or a shift fork maybe??? I got a buddy with a cobalt and his stick will do a complete circle. Lol. No shift point stops.
i thought gearbox was in good condition so i didn't open in before mounting.
shift fork is same for 1-2 gears. 1st gear doesn't have any problems
i'll do it in next weekend.here in my country there is no such part store where i can find b series transmission parts and that's big problem for my, because i must order parts in USA or UK and wait for it minimum two weeks
i disasambled transmission and got surprise!
shift rod is welded and not selects second gear properly
also stopper ring was installed not properly and was deformed
because of stopper ring 5 gear needle bearing was deformed too
second gear sleeve is not fixing at gear, ring is missing from synchro too
i will order second gear sleeve and synchro set at synchrotech but where can i buy all other parts? have anyone used gearbox for parts?
Jaydeep
Dec 22, 2009 08:38 AM
