Trouble Removing Rusted Exhaust Bolts
Old Sep 8, 2013 | 06:39 PM
kevinmcc2's Avatar
Default Trouble Removing Rusted Exhaust Bolts
So I was replacing my downpipe on my civic dx and was taking off the two spring bolts that connect the pipe that goes between the manifold and the back part of the car.
As you guess, both spring bolts snapped off. The only part left is the nut side, are these threaded into the pipe or do they use a nut?
I tryed to vice grip them with no luck, will a hammer work? I do not have access to torches.
Old Sep 8, 2013 | 08:46 PM
nanjay's Avatar
Default Re: Trouble Removing Rusted Exhaust Bolts
you can use a propane torch to heat the nut and cool it with water and ragg to take the nut off (small propane torch can be had cheap at homedepot, lowes, menards. or use a wire brush to clean the thread and use penetrating lube.
Old Sep 8, 2013 | 09:38 PM
instrument's Avatar
his last sentence stated he doesnt have access to a torch.....
anywho, have you tried prayer, my fam on facebook swear by it.
Old Sep 9, 2013 | 03:32 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Old Sep 9, 2013 | 10:23 AM
fragmare's Avatar
If you're doing DIY exhaust work at home, you're going to have to do some torching/grinding/cutting/drilling of broken bolts... no way around it. Those bolts become so corroded, over time, that no amount of PB Blaster or AeroKroil will do the trick.
Your best bet is to go out and buy a cheap torch and can of propane, heat it up, and drill it out or try to punch it through with a hammer and metal rod.
Old Sep 9, 2013 | 02:17 PM
nanjay's Avatar
i've stated he can buy a small torch at home depot....
If you dont have any to help the guy... then just keep your useless comment to your self....
jkalex05
Aug 8, 2009 02:09 PM
eskimo10
12
Jan 3, 2008 07:47 PM
White V6
Aug 3, 2005 08:19 AM
project dc2
Mar 13, 2004 09:59 AM
