Will this be bad to do...involves bolts on exhaust. Please Read. =)
Old Mar 30, 2003 | 08:11 PM
Zubz's Avatar
Default Will this be bad to do...involves bolts on exhaust. Please Read. =)
So I was installing a stock Si exhaust back on my car. There are 2 of those bolts with springs that connect the b-pipe to the axleback. Well I realized that one of the bolts was actually broken off and stuck inside the threading. It happened when I originally removed it, but forgot about it.
So I'm gonna drill it out, but that means I wont be able to use the spring bolts again. They wont re thread in there, and they are the type without the nuts. Think its OK to use a normal bolt and nut without the spring setup? How crucial are those?
Old Mar 30, 2003 | 09:06 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Will this be bad to do...involves bolts on exhaust. Please Read. =) (ZubzSi)
it just allows the pipe to flex and not break. i would put new in.
Old Mar 30, 2003 | 09:07 PM
aut0tek's Avatar
if I'm not mistaken the spring isn't attached to the bolt. Drill it out and put a new one in with the spring on it... and a nut. I actually had a similar problem and I made an exhaust bolt out of a timing cover bolt using a dremel tool to shave down the little edge that mates the bolt up to the pipe and put a big washer on the head... worked great and is still working to this day.
(then again, that's the same joint that has a Ford Probe donut gasket and a bunch of other crazy fabrication cuz I had finally got the swap done and was anxious to get it out. hahaha)
HTH.
Harry
huge230
Aug 23, 2007 12:11 PM
Floored
Jul 17, 2006 07:37 AM
sohctodohc
May 22, 2005 08:43 AM
bzyrice
20
Jun 25, 2003 02:11 PM
