Cam timing q
Old Sep 6, 2013 | 08:48 AM
SiRCiviC94's Avatar
Default Cam timing q
I did the timing for the first time. Exhaust cam first rotate 3 teeth and tighten. Rotated 5 times with crank at tdc. Best I could get it both the marks on the sides to line up and gears pointing up but slightly forward with the crank back at tdc. Car starts fine no issues just wondering.
Also ignition timing is spot on so does the re assure
I did it right?
Old Sep 6, 2013 | 08:53 AM
jdmh22eg2's Avatar
Default Re: Cam timing q
sounds good to me.
with honda its a good or bad thing but if you get it wrong you will know FAST. either no start or cam timing off enough to bend valves either way you WILL know
Old Sep 6, 2013 | 09:45 PM
SiRCiviC94's Avatar
good to hear. she fired up after a full top to bottom clean up and build with the touch of the key. just a cleaned up b16a head and block.
SouthSider13
Oct 15, 2010 01:24 PM
civiccoupe94
Jan 11, 2008 07:08 AM
Project_CD5
Jul 25, 2007 03:20 AM
00Red_SiR
Feb 10, 2007 06:49 AM
civickiller
Mar 8, 2004 11:34 AM
