Help: Civic eg si with b20z swap blower no Heat~
hi guys, i just did a bone stock B20Z motor with b18b IM in my civic eg HB and for some odd reason the car overheats, then the blower will only blow hot air when i have my foot on throttle. can someone please explain the situation i am in?
Did i hook the coolant hoses wrong or something?
i could locate if there are any leaks from the hoses but can't explain why the heat only works when i have throttle. A/C works fine by the way.
thanks guys~
thanks guys~
i have just upgraded the radiator to aluminum one's and a lower temperature thermostat (71C)
Both upper/lower radiator hoses are hot at idle, fan turns on but still no heat whats going on guys? i really need help on this...
If you use the correct hoses, they are shaped to hit the proper fittings so they cannot be mixed up
goto honda parts now and look up the hose routing
hondaparts diagram are partially pix not the full diagram
thanks
wow
thats awesome man~ thank you so so much for the diagram
oh ~ i did leave the cap off and let the engine running for 40mins or so(fan kicked in twice while idle), would that be enough? or i still need to bleed from the thermostats bleed valve?
doubleoazn03
Nov 26, 2012 12:20 PM
jayeghatch
12
Aug 25, 2012 02:26 PM
jrvargas09
Nov 16, 2011 08:00 AM
Louie_EM1
Feb 28, 2004 09:39 PM
