GSR into EK hatchback.
Old Aug 19, 2013 | 09:44 PM
TORTUGA's Avatar
Icon6 GSR into EK hatchback.
I'm looking into swapping in a JDM GSR into my 96 hatchback (CX). Only problem i'm having is that i'm unsure on what to do with the GSR harness and my single cam harness (Non-Vtec). I've done some research and have found out that I have to use my single cam harness in order to make it work. I have a P28 ECU laying around that I would like to use, along with the OBD2A-OBD1 jumper harness. Can someone please give me some help/info on where exactly to start? Any plugs I would have to change? Extend? Any info would be greatly appreciated. Thanks in advance.
Old Aug 19, 2013 | 10:12 PM
Marvin1985's Avatar
Default Re: GSR into EK hatchback.
Look into the FAQs. This is covered. What year gsr
Old Aug 19, 2013 | 10:17 PM
TORTUGA's Avatar
96
Old Aug 20, 2013 | 12:12 AM
robbieshonda's Avatar
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A-%2A-obd1-b-series-engine-into-obd2a-obd2b-civic-integra-%2A-%2A-1972711/
Old Aug 20, 2013 | 12:51 AM
frost_white_ej1's Avatar
why would you want to use a p28 on a gsr motor? unless it chip for the motor you intend to swap in i wouldn't do it.
Posted from Honda-tech.com App for Android
Old Aug 20, 2013 | 01:17 AM
HondaPartsHero's Avatar
Technical Hero
Check out my thread it should answer most of your questions, but in a nut shell you'll need:
-use your harness
-wire in VTEC
-convert your 3 wire IACV to 2 wire
-using the p28 you won't need to extend the 2nd 02 or wire up knock or IABs
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-honda-engine-swap-wiring-guide-vtec-non-vtec-2987229/
Old Aug 20, 2013 | 08:50 AM
TORTUGA's Avatar
It won't be necessary to extend any sensors then?
mish__
Apr 7, 2012 07:09 PM
jorgejam2001
Sep 25, 2009 08:47 AM
thewonderer
10
May 31, 2005 11:20 AM
dropcivc
Oct 3, 2002 10:04 AM
Homericaeast
May 21, 2002 07:06 PM
