You let me down synchrotech...
Old Aug 19, 2013 | 10:59 AM
Nottjbarlow's Avatar
Default You let me down synchrotech...
So i rebuilt my dohc zc L-3 tranny and used the fifth gear out of my hf trans( for lower highway r's... No more 4200 rpm at 80mph) and the kit i got was a full seal, synchro and bearing kit. For one it does not come with diff bearings and two the fifth gear synchro spring clip/ring was very weak( but i put the new one in and sure enough fifth grinds if i dont shift REALLY SLOW. So i was thinking has anyone tried putting two rings on a synchro for better gear slow down??? Or even is it possible. Also the old clip is stronger than the new so back to square 1.
Old Aug 19, 2013 | 11:54 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: You let me down synchrotech...
How was the teeth on the sleeve itself for that HF 5th gear set?
Old Aug 19, 2013 | 12:34 PM
4drEF's Avatar
Keyboard Humorist
They really can't send you the diff bearings as there are different bearing sizes. i believe that it is pretty standard not to include them with a tranny bearing set.
That is bad about the weak ring though. Can you just get one from Honda?
Old Aug 19, 2013 | 01:44 PM
Yet on the website they ask if you have 35 or 40mm bearings hmmmm? Neways i was thinkin about just using the old clip.... It felt much stronger. But really dont want to yank the engine ... Again!
Old Aug 20, 2013 | 10:16 AM
parts@synchrotech's Avatar
Hello and my apologies for any misunderstandings you may have had with our kits. On our website for example:
http://shop.synchrotech-transmission...SYN111-D16.htm
We list all the items that are included in the kits so that our customers know exactly what they are ordering. We also use detailed photographs that match the descriptions. There are a couple of reasons why the diff bearings are sold seperately:
1. Not everyone wishes to replace them
2. There are different bearing sizes that can be used as 4drEF mentioned. This goes across the board with the majority of Honda/Acura transmissions so we decided to keep consistency to avoid confusion.
3. The reason we ask whether you have a 40mm or 35mm bearing size is because that is one way to identify what bearings your transmission has so the correct shaft bearings are sent out with your kit.
I hope this clears up any confusion or misunderstandings. You could have also called us at any time during business hours to discuss what is included in our kits or if you needed any type of clarification and or tech assistance. Many of us here have been working with Honda/Acura transmissions for over 10 years.
As far as the synchro spring is concerned...if you feel the spring is defective. We will be more than happy to replace it at no charge. I would like to know the condition of the gear and the sleeve for 5th gear as that is more likely to be the cause of your grind issue. Let us know so we can help you get your vehicle back in working order
Old Aug 20, 2013 | 05:10 PM
sumdewd's Avatar
I've been using a Synchrotech DX transmission for almost 2 years now and have had no issues. I'm sure they will do you right if you give them the chance.
Old Aug 20, 2013 | 06:12 PM
TypeRfit's Avatar
RESIDENT
Synchrotech will never let you down, anytime companies are mass machining parts there are a few that will slip through QC, one thing you will never have to worry about with Synchrotech is their customer service as James stated above. One of the top notch companies still around.
Old Aug 20, 2013 | 06:30 PM
Its more my fault for not checking..... But you live and you learn i guess.
Every part was still in spec. I put the old synchro spring on the new synchro, it had a much better resistance against the synchro hub than the new one... No worries tho s**t happens, It made me very happy to see the rest of the parts were made in japan I HATE CHINA MORE THAN WE ALL LOVE HONDAS.
Any ideas where to get L-3 diff bearings and a counter shaft locking nut??
Old Aug 20, 2013 | 06:49 PM
About the bearings was a joke but where can i get the locking nut
Old Aug 21, 2013 | 12:39 PM
We have the differential bearings in stock A new locking nut can be purchased from the dealer.
Old Aug 21, 2013 | 03:14 PM
Yea seen the bearings on there after i sent the post stupid me getting ahead of myself. Thanks for the follow up... This was my first trans rebuild, and other than the synchro clip (i'll get the new one) the ol' L-3 feels slippery than k-y
You have my business for life.
Old Aug 22, 2013 | 06:29 AM
Dark_Teg's Avatar
I love my Synchrotech built B16S1. Best money I have spent on the Honda...
unclematt
Dec 9, 2008 04:24 PM
vdawg559
12
Jun 9, 2008 06:21 AM
Ek00fbp
Mar 1, 2004 04:25 AM
Tire Monkey
Jan 29, 2004 12:19 AM
