1st gear sounds like reverse when hi rpm
just like topics says. sometimes it would go when i slowly steeping the gas. when i shift second you can slighty hear it. but sometimes not. what can it be guys.
- put the vehicle up the lift. an put it on first gear an step on the gas, no noise has been made.
- replace driver side wheel bearing.
-people opinion.
- throw out bearing
- transmission
-caliper piston isnt disagaging
an last. does anyone know what teh problem is? or has ran across it? im getting very angry
-people opinion.
- throw out bearing
- transmission
Re: 1st gear sounds like reverse when hi rpm (vdawg559)
my tranny does the same thing. from what i hear, it should be the input shaft bearring in the trans.
Re: 1st gear sounds like reverse when hi rpm (socallmechris)
bad tranny bearings, both mainshaft bearings and the countershaft top bearing are the most failure prone.
my car does the same thing it would whine in second but recently it stopped and is now doing it in third
i was thinking it was a throw out bearing
are you having any problems going in and out of gear ? like it sometimes it feels like the clutch isnt disengaging ?
Re: 1st gear sounds like reverse when hi rpm (Fullthrottle297)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fullthrottle297 »</TD></TR><TR><TD CLASS="quote">my car does the same thing it would whine in second but recently it stopped and is now doing it in third
are you having any problems going in and out of gear ? like it sometimes it feels like the clutch isnt disengaging ?</TD></TR></TABLE>
yup same problem second seems to stop an now 3rd. gettin
anoying. all my friend says its teh throw out bearing but iono
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxsir2 »</TD></TR><TR><TD CLASS="quote">have u tried changing the tranny fluid and seeing what it looks like?</TD></TR></TABLE>
nope. nothing yet. trying pinpoint what exactly is the problem. cus after the whine stop it drive normal
so what did most of you guyz did that have the same problem? did you guyz replace the tranny???
when i step on the clutch. the lil rattle noise goes away. but when its normal you can hear an slight noise..... soooooo...
your saying. my clutch is go out also??? if so. i was already planing on getting a new clutch
Re: (vdawg559)
for the last time....the bearings in the transmission are bad. this happens all the time on these. It will have to be cracked open and have several bearings replaced. its NOT the throw out bearing.
Re: (vdawg559)
Definitely sounds like a throw out bearing if it makes a noise then you push in the clutch and it goes away as for the clutch you will be able to tell if its bad when you take the tranny out to change the bearing
NipponRacing
05-03-2003 03:09 AM
