Idle issues
Old Aug 15, 2013 | 12:57 PM
.Gen2gsr.'s Avatar
Default Idle issues
Have no idea what to try next, The car idles fine when cold but when warm i get a slight idle surge from about 750-900 rpm. Ive tried everything I can think of set the idle as per the book as well as timing, tried new sensors ecu gaskets only thing left that has not been changed was my distributor.The car throws no codes or no codes stored.
Its a 92 Teg with a b18a block b18b head using b18b valve lash, the head was recently service and replaced the valve train for dual spring and supertech valves to run with my cams once i get this figured out.
also using a blox manifold and a ported itr tb.
Anyone have any ideas or suggestions on what to try.
Old Aug 15, 2013 | 01:54 PM
B_Swapped93's Avatar
Default Re: Idle issues
yes, clean the IACV when was your last full ignition tune up ? have you bled the coolant system ?
Old Aug 15, 2013 | 03:12 PM
NameGoesHere's Avatar
+1 on IACV cleaning. Report back after and let us know if things have cleared up or not.
Old Aug 15, 2013 | 11:48 PM
.Gen2gsr.'s Avatar
iacv sadly is not the issue I will check my spark plug wire and see if they are good other then that cap and rotor is new.
Old Aug 18, 2013 | 08:42 PM
.Gen2gsr.'s Avatar
well wires are all with in factory spec after I tested them. What are the common steps to go through to figure out this idle issue since its not the iacv
NayborhoodJohnny
Feb 8, 2011 07:44 PM
ekhatch66
Engine Management and Tuning
Sep 7, 2009 07:47 PM
95hbMatt
May 25, 2003 08:05 PM
s2k
Feb 25, 2003 06:50 PM
