integra b18b idle issues
Old Feb 2, 2011 | 09:41 PM
NayborhoodJohnny's Avatar
Default integra b18b idle issues
ive cleaned the iavc or whatever from the DIY
my car warms up at around 2500 rpms.
when it idles it wavers from 1100-1400 rpms.
anyone know how to get it a lower?
Old Feb 2, 2011 | 11:45 PM
blacklabel14's Avatar
Default Re: integra b18b idle issues
you put a B18b in a DA those come stock B18a u need to switch around some things
Old Feb 3, 2011 | 11:23 PM
what would i switch around?
what could cause something like this?
Old Feb 4, 2011 | 03:51 AM
Bowl_of_Rice's Avatar
a little vacuum leak could cause it, try adjusting your idle screw
Old Feb 4, 2011 | 02:10 PM
wtf_is_jdm's Avatar
So your saying It idles high on cold start, and after warming up it kicks the RPM into variating idle correct?
Old Feb 7, 2011 | 09:05 PM
yea it starts at 2500, goes up to 2800 or so
then it ranges (goes up and down) from 1500-2800, and as it warms up it slowly mellows out
when its warmed up and idleing, it ranges from 1200-1500.
the idle screw is screwed in tight... not to sure how to adjust, the flat head i used wouldnt budge it and it kind of ruined the screw.
Old Feb 8, 2011 | 05:29 PM
wtf_is_jdm's Avatar
CEL's?
Old Feb 8, 2011 | 05:58 PM
ElementzofR's Avatar
check the FITV
Old Feb 8, 2011 | 07:35 PM
hatmanafro's Avatar
Whats the FITV? im curious as i have this exact same problem.
Old Feb 8, 2011 | 07:44 PM
Fast Idle Thermal Valve. its under the throttle body. has 3 10mm bolts and 2 small coolant hoses coming out of it.
2ndchirp
Dec 13, 2009 11:08 AM
ekhatch66
Engine Management and Tuning
Sep 7, 2009 07:47 PM
dsmarefaster
May 15, 2005 03:55 PM
Audipwr1
Jul 6, 2003 10:27 AM
