burning 2l of oil every 8 months
HI GUYS GLAD TO BE A PART OF THE FORUM HOPEFULLY FOR A LONG TIME..
I HOPE THIS IS THE RIGHT SECTION
IM IN THE PROCESS OF GETTING A CIVIC TYPE R EK9 WITH A B18c4 ENGINE WITH A T04 TURBO CONVERSION..
WHEN THE CARS LEFT TICKING OVER FOR A WHILE AND YOU THEN BOOT IT THE CAR THRROWS BLACK SMOKE WHICH IM ASSUMING IS RUNNING RICH??
ALSO THE CARS USED 2L OF OIL IN 8 MONTHS
MY QUESTIONS ARE
1. WHAT CAN I DON ABOUT THE MIXTURE THE CHEAPEST WUICKEST OPTION UNTILL I CAN GET A HONDATA OR SOME SORT OF ECU TO LIVE MAP IT.
2. IS THAT NORMAL TO USE 2L OF OIL IN 8 MONTHS
ANY HELP BEFORE I GET THE CAR TO EITHER GET IT OR PULL OUT OD THE DEAL ..
THANKS VERY MUCH GUYS THIS SITE COMES RECOMMENDED HOPEFULLY YOU CAN PROVIDE HELP
THIS IS THE CAR
MY QUESTIONS ARE
THIS IS THE CAR
Need more infor.
Bigger injectors on stock ecu?
Burning alot of oil can mean the piston rings are gone, valves bad, or blown turbo.
He'll even an oil leak. So it just all depends.
sorry guy said its got 550cc injectors and a non vtec auto ecu??
not sure how that ecu runs with that engine any iodeas thanks buddy
numbers and code on ecu are as followed
37820-p06-g50
481-730492
AUN
37820-p06-g50
481-730492
AUN
The guy claims its had a live map on it? But I thought these ecus couldn't be mapped only chipped ? He also mentioned inside the car smells of fuel that's why black smoke one enitial foot to the floor then it clears
What would be ring/ cylinder symptoms other than blue smoke ?
2L of oil in 8 months? dude the engine is old. yes.
it could very well be leaky valve seals, turbo burning small amounts of oil etc.
I also don't know many people who go 8 months without changing oil
the guy says the smokes only happens when cars been sat ticking over and when you first boot it only happens the once only. and says the fuel smell is only now and again.
maybe im being over precausious but just thought ide get your top advice first , the car drives and boosts very well and boy does it move. it starts fine , ticks over fine and like i say only gives one little puff if left ticking over for a while
Valve stem seals then.
The oil drains down the valves and into the cylinders. Burns off on first start up and then while everything is hot and moving it is sealing.
singingstallion
Jun 13, 2005 06:01 PM
