D16Z6 - got an oil leak
Old Jul 1, 2013 | 08:29 AM
tony_da_tiger's Avatar
Default D16Z6 - got an oil leak
OK so I cleaned the engine and tranny yesterday with some simple green and hosed it off dried it with some paper towels and it looked awesome now this morning after a run to the store I smelled some oil burning thought it was the old vw next to me so I get home pop the hood and see this ¶ anyone know where that could be leaking from thanks in advance
Old Jul 1, 2013 | 08:35 AM
Default Re: got a leak
I guess the old build up was masking the problem and cleaning it just pissed me off know I need to fix it lol I have a slight ocd and it will bug me till its done I'm thinking maybe the dizzy o ring but no leaks inside the cap
Old Jul 1, 2013 | 08:45 AM
JuggerNaut-CTR's Avatar
Did you try and trace where its coming from? You should be able to follow the path of fresh oil.
Since the vtec solenoid is on the back side, I would guess the dist. o-ring...
Old Jul 1, 2013 | 08:52 AM
Thanks for the input I did try and trace it burned my hand and nose in the process lmao it seems to be under the distributor
Old Jul 1, 2013 | 09:03 AM
Just did another search and supposedly there is a internal and external seal so I guess I'll be ordering those today if its the problem
Old Jul 1, 2013 | 09:05 AM
Former User's Avatar
Seeing oil in the pictured location is generally the distributor O-ring and/or the VTEC solenoid, the latter of which has two separate oil seals.
Old Jul 1, 2013 | 09:06 AM
If the internal seal is bad, you'll find oil inside the distributor. Have you removed the cap, rotor, and inner cover to inspect?
Old Jul 1, 2013 | 09:59 AM
purgat0ry's Avatar
This
Also, it's like a 90c gasket, replace it for peace of mind.
Old Jul 1, 2013 | 11:29 AM
Default Re: D16Z6 - got an oil leak
Vtec solenoid gasket was bought new when I polished it and I found the leak I made a rookie mistake by not adding rtv to the corners when i changed valve covers so it was seeping out from the rear corner thanks for the input guys
VTECwalka
10
May 24, 2012 05:09 PM
jdmsir4dr
Jul 26, 2010 08:09 PM
94egb16
Nov 29, 2006 06:21 PM
integracivic94
Jan 8, 2005 01:03 PM
redciv
Feb 4, 2004 02:45 PM
