Transmission & Drivetrain Gearboxes, Differentials, Clutches
Checking an ITR Differential
Old Jun 28, 2013 | 02:36 AM
7rrivera7's Avatar
Default Checking an ITR Differential
I'm rebuilding my YS1 cable transmission due to a slight grinding of 3rd gear during high shifts and I'd like to test the differential to make sure it's working properly. Is there a visual inspection? If I remove the ring gear screws, if their a way of making sure everything is fine besides just a visual inspection of the internals?
Old Jun 28, 2013 | 11:12 AM
Rocket's Avatar
Default Re: Checking an ITR Differential
I have never seen a bad differential; other than one that had broken spider gears.
You can check to see if the backlash on the spider gears are within factory recommended specs.
Old Jun 28, 2013 | 12:37 PM
Aquafina's Avatar
The process for checking it is in the ITR Helms manual.
If you don't have one, just visually inspect the contact patch on the gears for wear and check the case halves for wear where the gears ride (this is where the wear usually occurs on the OEM helical LSD's).
Old Jun 28, 2013 | 12:39 PM
Rocket's Avatar
^^good point; it's a helical (Quaife style) LSD, no spider gears.
Old Mar 28, 2015 | 05:50 PM
gmcuajo1's Avatar
Bumping an old thread, but I think is better to revive one than making a new thread.
Is there any DIY or tutorial on how to do it properly?
Black R
Mar 9, 2017 09:11 AM
7rrivera7
Jun 28, 2013 04:32 PM
OH_1fstgsr
13
Jul 19, 2011 09:32 PM
b20vdelsol619
Aug 29, 2009 12:41 PM
IC x Prince
Jan 27, 2003 09:39 AM
