Distributor question on a d series.
So i bought a 93 del sol for teh lows. It came with a d15z1 that came from a vx, my question is could i use a distributor from any other d series? Thanks in advanced.
I do not know yet. I bought the car as a shell and just recently dropped the motor in, I dont have the ditributor and other misc parts to start it. I was just wondering before I purchase the part if I can get away with using another distributor.
Its an si, so all it had before was the original motor.
My problem is not having any type of distributor on the motor currently, Im trying to take the economical route and find one that can work.
92-95 D16Z6 is the only other one that will bolt up perfectly. However the Z1 in that car is going to cause you a ton of wiring headaches if you attempt to run it on the stock ECU.
ferio-ichi3
17
Nov 5, 2015 12:11 PM
raidacaipo
May 24, 2009 09:28 AM
