Will a B series distributor work on an H series motor?
Re: Will a B series distributor work on an H series motor?
alright thanks.. the reason I want to change my distributor is because Im getting a CEL 4 which is crank position sensor. I believe its going bad and my rpm doesnt read properly.. when it idles its completely at 0 and when I rev it, it bounces all around. Is this the cause of a bad distributor?
the right distributor to use is td-60u they are on ebay for about $120 its an h22 with internal coil so it will bolt up and fit the wiring harness
bad, bseries, cap, coil, distributer, distributor, distributors, fit, h22, hseries, internal, motor, pattern, series, work
