Transmission & Drivetrain Gearboxes, Differentials, Clutches
Could a transmission cause the axle not to turn?
Old Jun 4, 2013 | 03:58 PM
Stealthyy's Avatar
Default Could a transmission cause the axle not to turn?
My mechanic is saying that the differential in the trans is not turning the axles but it shifts fine?
Old Jun 28, 2013 | 03:07 PM
lazmashery's Avatar
Default Re: Could a transmission cause the axle not to turn?
Does it make any noise while youre in gear, release the clutch as if you want to move from a dead stop? The shifting components and differential are totally unrelated, and one may work without the other. Put the car in gear while car is off(apply e-brake), lift the car in the front and rotate the tires by hand to see what the other tire does. If One tire spins and the other one doesnt while its in gear, there is something wrong with the differential(assuming you have a working clutch).
Old Jun 28, 2013 | 03:09 PM
lazmashery's Avatar
BY THE WAY, also assuming BOTH axles are snapped into the differential as they should. When an axle retaining ring becomes worn, it will pop the axle out and cause similar symptoms. hope it helps.
Oscar
donnieb22000
Jun 17, 2018 09:12 AM
turbocivic0618
Oct 10, 2005 10:53 AM
-[95cxhatch]-
Mar 20, 2004 10:49 AM
persain488
Mar 10, 2003 10:54 AM
darkfx
40
Sep 16, 2002 04:34 PM
