Heater Hose bypass
Old Jun 2, 2013 | 06:12 PM
88h22_CRX's Avatar
Default Heater Hose bypass
I'm not sure if this is the right section but, here's my situation.
I have my h22 out and I'm prepping it to put back in. I was wondering since my new shell (CRX) doesn't have a heater, can I just connect the two coolant outputs that normally go to the heater together? Like get a hose long enough to go from the head over to the other outlet behind the water pump?
I can see on the head I could find a plug and just plug it but, by the water pump, how could I plug that?
Old Jun 2, 2013 | 06:13 PM
88h22_CRX's Avatar
Default Re: Heater Hose bypass
Second picture.
Old Jun 3, 2013 | 03:19 PM
slowcivic2k's Avatar
Yes, link them together, you will be fine.
Old Jun 3, 2013 | 03:49 PM
88h22_CRX's Avatar
Ok cool. I thought so, just wanted to double check. Too bad they don't make a cover for the back of the water pump. Oh well.
Thanks
Old Jun 4, 2013 | 05:52 PM
2kdrift's Avatar
sealed my b16 heater hoses with endcaps from oreilys, works fine no issues yet
Old Jun 4, 2013 | 06:11 PM
88h22_CRX's Avatar
Sweet! Could you be a little more specific. Like what section, etc. Or do they sell specific hose end caps?
Thanks, I'll definitely look into that.
Old Jun 10, 2013 | 01:23 PM
DO NOT put end caps on those fittings! You must circulate water so the thermostat opens.
Old Jun 10, 2013 | 01:43 PM
88h22_CRX's Avatar
Ok. I saw how they sell them for the K-series, so I figured it would work for the H-series. This car will not be driven on the road. As far as that goes, what would prevent me from just taking the thermostat out completely? I know its purpose is to allow the engine to get to operating temp before allowing coolant to circulate, but if its a drag only, I should be fine right?
Old Jun 20, 2013 | 02:35 PM
2kdrift's Avatar
might get flamed for this
but i dont have a thermosat either, live in Hawaii weather is never under 70 degrees and never over 90 year round. I have read the debate about the water circulating to fast and not actually cooling the block enough but it seems to run fine with no thermostat (technically i have a thermostat but i cut the pring and valve out and just use teh body with gasket. as for the plugs them self they are universal come in a pack of 5 or 6 in assorted sizes, not specific to a engine and can be used on all makes. I believe they were near the vacuum hose adaptors/ blockoffs. I asked an associate for heater hose plugs and he knew exactly what i was talking about i think the pack was less then $5
Duzercivic97
12
Oct 6, 2012 06:48 PM
q16racer
Honda S2000
Nov 14, 2011 10:58 AM
mac_24_seven
Dec 29, 2008 01:27 AM
EGB18C
Feb 29, 2008 06:26 PM
speedymon
Nov 14, 2002 10:44 AM
