Flushing coolant w/o removing drain plug
Old Nov 14, 2002 | 10:10 AM
speedymon's Avatar
Default Flushing coolant w/o removing drain plug
Want to flush the coolant in my gsr but my turbo is in the way of the drain plug on the block. Can i just flow water through the upper radiator hose towards the head, through the engine and out of the lower hose. Will this damage anything (water pump)?
Old Nov 14, 2002 | 10:29 AM
redline's Avatar
Default Re: Flushing coolant w/o removing drain plug (speedymon)
You can do that, it will not hurt anything but i am not sure if you will get a good flush or not.
Old Nov 14, 2002 | 10:39 AM
intekragsr's Avatar
Default Re: Flushing coolant w/o removing drain plug (redline)
https://honda-tech.com/zerothread?id=330857
Old Nov 14, 2002 | 10:44 AM
speedymon's Avatar
Default Re: Flushing coolant w/o removing drain plug (intekragsr)
Thanks alot
Duzercivic97
12
Oct 6, 2012 06:48 PM
atikovi
Oct 7, 2010 05:49 PM
camera obscura
Jul 13, 2004 06:04 PM
xavior66
11
Jan 21, 2004 01:27 PM
R249
Jan 24, 2003 04:17 AM
