Speedometer issues
Old Jun 2, 2013 | 05:01 PM
CXHBumpin39's Avatar
Default Speedometer issues
I need some help... So my speedometer works normal most of the time, but sometimes it jumps to higher speeds than I'm driving, it quickly comes back down, when it does this is makes a clicking noise, it sometimes does this a few times in a row, I've cleaned up the points on the VSS and the throttle position sensor, I'm wondering what else to check, possibly clean up grounds? And if that's a good idea where would I find these grounds
Old Jun 2, 2013 | 05:29 PM
Default Re: Speedometer issues
My car is a 1992 Honda civic for those wondering
Old Jun 2, 2013 | 11:39 PM
holmesnmanny's Avatar
Get another speed sensor from the junkyard. If it does the exact same thing then the problem is the cluster.
Old Jun 3, 2013 | 11:35 AM
meaning that i need a new speedometer? cuz i have changed that. not with a new one, but with a used one that was tested and fully functional...
Old Jun 4, 2013 | 12:09 AM
speed sensor does not equal speedometer
Old Jun 5, 2013 | 07:13 AM
Sorry I miss read, but now the speedometer goes to zero for minutes at a time, can this really all be caused by a bad speed sensor? Just wondering cuz I have a lot of money in this car and would like to not spend money on the wrong stuff
Old Jun 5, 2013 | 10:28 PM
lol the speed sensor is what tells the speedometer what to read. Obviously if the speed sensor is bad it will mess up the speedometer. Considering you said you replaced the speedometer on the cluster already and that didn't fix it it can really only be the speed sensor or somehow the wiring it intermittently going open.
Old Jun 9, 2013 | 10:07 AM
Well I was thinking if the sensor was bad then it always wouldn't work correctly, but it just doesn't work right sometimes, I changed the sensor anyways, Ill check if it fixed it once I get my fuel pump changed so I can drive it again
Freckles
Aug 20, 2012 10:30 PM
y2kferari
10
Aug 19, 2009 11:13 AM
aziaticvang
Jan 13, 2008 06:35 PM
slow4dr
Dec 27, 2004 07:19 AM
PSU
May 11, 2002 10:30 PM
