P28 resistors missing???
Old May 29, 2013 | 09:11 AM
turbodcxbro's Avatar
Default P28 resistors missing???
I just chipped this P28 for a buddy and noticed this hack job down by the EPROM socket... someone appears to have "replaced" a resistor with this piece of wire and I'm trying to figure out why... the ECU ran the car prior but it had a solid CEL and I couldn't pull the codes.
When I chipped it, put a P28 Crome gold Base tune in the CEL stays on and the car doesnt rev past 4000rpm. Tried burning several chips and it does the same thing. We swapped ECU's and it runs fine.
My question is, is this missing resistor important and is it conflicting with my chipping job (done several with no problems) or did I mess up somewhere? Anyone seen this type of "repair" on an ECU before?
Old May 29, 2013 | 09:21 AM
JupiterEF's Avatar
Default Re: P28 resistors missing???
completely normal this ecu was an auto ecu and someone converted it to 5speed. normal.
did you remove the checksum when you burned the tune?
if not it would cause it to go into limp (4K rev limit)
Old May 29, 2013 | 09:31 AM
Aha! so this is all thats done for a A/T to 5 speed conversion? sweet, didn't know that.
Yes, removed the checksum every time, still a solid CEL and 4k rev limit.
Old May 29, 2013 | 09:37 AM
JupiterEF's Avatar
what programmer are you using?
Old May 29, 2013 | 10:44 AM
Moates Burn 2 and Crome Pro.
Old May 29, 2013 | 10:45 AM
The more I read, I'm thinking I have a cold solder joint on the 74HC3 latch chip... gonna resolder tonight.
Old May 30, 2013 | 06:24 AM
sorry, if you don't have anything constructive please don't waste my time or yours. Hondas are new to me, I've been tuning Fords/GM's for many many years. Great way to promote your business too by the way.. I'll surely be ordering from you when I need something... NOT!
Old May 30, 2013 | 08:22 AM
First of all they are not customers, they are friends that I'm helping out that don't want to touch an ECU or soldering iron. I don't charge a dime. I've researched chipping ecu's enough to know how to perform a simple chipping procedure, nothing ever came us as far as changing from A/T to 5 speed, so no I've never looked into that nor have I done it.
Truth doesn't hurt one bit fella, guess your business is doing real well for you to have all this time on your hands to be on here trolling my simple post picking arguments... get a life pal.
Old May 30, 2013 | 01:28 PM
odz-fab's Avatar
you once were a noob no?? probably still a noob to sex life and friendships
Old May 30, 2013 | 02:02 PM
odz-fab's Avatar
it is... sigh........
Old May 30, 2013 | 02:14 PM
odz-fab's Avatar
OP i too searched and chipped my own ecu with information found on the net.. and auto to 5speed didnt come up unless you directly looked for it .
Old May 31, 2013 | 03:57 AM
Looks like he (or someone) deleted all his replies! lol...
Anyway thanks for the help guys, got it all straightened out with your help and the other HELPFUL folks here on H-T.
Old Jun 1, 2013 | 04:14 AM
7rrivera7's Avatar
I deleted them - too much drama...
red Teggie
Dec 28, 2011 12:17 PM
drshottest718
May 22, 2006 04:31 PM
Mr.Death
Jul 9, 2005 06:50 PM
BoredRec
Sep 27, 2004 09:31 PM
