Fans not coming on. h22 prelude
1992 prelude with 93 h22a jdm swap
The 2 fans in the engine bay dont come on
The car doesnt over heat
The relay in the engine bay fuse box is fine.
The fans are plugged in
What could it be...
thanks
What could it be...
thanks
None go on when i turn the ac on
i dont know how or where to apply power. i need to search that
How easy is it it to change the temp sensor. how do i check if the stat is stuck open.
thank you
thank you
coolant temp sensor. right next to the head there are 2 a single wire one and a 2 wire. change the sensor it could be bad. hondas have 2 where your coolant temp guage still wotks but switch doesnt come on. had that prob on my teg. easy fix. you just need a ratchet and a long socket that fits. out sealer on it when you put the new one in. let me know how it goes.
Ok ill check it tomorrow. im at work now until midnight. ill post up results.
my friend told me the fans take a really long time to turn on.
but the ac fan should come on right away
https://honda-tech.com/picture.php?a...ictureid=39234 both of those
awesome its the one on the left and right. not the middle one right
