how would a car feel with a bad map sensor?
Old May 17, 2013 | 06:16 PM
russ.shafer's Avatar
Default how would a car feel with a bad map sensor?
I have a 01 gsr no codes, I cant figure out what is wrong with it. the only thing I havent changed is the map sensor and im running out of money to put in this car. it is really sluggish and dosent feel like a gsr. vtec is working. had any one had to replace a map sensor? if so what was your car doing before you changed it ???
Old May 18, 2013 | 05:37 AM
m4xwellmurd3r's Avatar
have you checked fuel pressure, ignition timing, good spark, etc. i think when a map goes bad it either wont run at all, or could possibly make it pig rich.
Posted from Honda-tech.com App for Android
Old May 18, 2013 | 06:22 AM
B_Swapped93's Avatar
Default Re: how would a car feel with a bad map sensor?
Ohh it sure does....learned the the hard way lol yes slugishness can be an affect how do your plugs look ?
Old May 18, 2013 | 06:34 AM
GagnarTheUnruly's Avatar
You need to do some actual diagnostics and not just throw money at the problem.
Old May 18, 2013 | 09:52 AM
It's kinda hard when it's not throwing any codes
Old May 18, 2013 | 09:55 AM
just cause it's not throwing a code doesn't mean you can't troubleshoot
Old May 18, 2013 | 02:56 PM
Yeah there is a lot of information to be gained with a multimeter.
Old May 18, 2013 | 06:28 PM
I have a multimeter. Tell me what to check. I've checked and calibrated the tps ,I guess I'm going to order a fuel pressure gauge to check fuel pressure. The only code I get is when I un plug the map sensor.
Old May 18, 2013 | 06:33 PM
well that's correct
https://honda-tech.com/forums/honda-accord-1990-2002-2/map-sensor-test-3010261/
Old May 19, 2013 | 12:07 PM
Map sensor was fine. The timing belt tensor was screwing up causing it to jump off time. Problem fixed. !!!!
Old May 19, 2013 | 02:29 PM
Awesome! I'm glad you got it worked out. The best advice I can give in the future is to pick up a Helms Service Manual. They have flowcharts for different symptoms and make it much easier to troubleshoot efficiently.
I'm thinking some day I might post a guide for people who don't have Helms manuals, since lots of people these days are having tune issues.
MatthewMenze
Engine Management and Tuning
May 1, 2014 01:24 PM
D-Rizzle3
Mar 1, 2008 09:51 AM
Tyler Con
Oct 10, 2007 11:53 PM
dizzyek
May 17, 2006 09:38 AM
Pnoymugen
Apr 23, 2004 04:13 PM
