Map sensor gone bad?
Old Feb 19, 2008 | 07:53 PM
D-Rizzle3's Avatar
Default Map sensor gone bad?
So the other day i was driving and my car started missing and dumping alot of fuel. It did it two times before finally taking a dump..i was wondering everyones opinions on what they think is the problem. I hear map sensor alot bc it sounds like its running on 2 cylinders and theres a strong smell of fuel. Anyone know where to get a plug and play 2.5bar map sensor if this is the case?
Old Feb 19, 2008 | 08:09 PM
arc_55's Avatar
Default Re: Map sensor gone bad? (D-Rizzle3)
A little bit more info on your setup would help. More infor in regards to the managment system... obd1? what are u tuned with? closed loop or open loop? Any codes?
Fuel is most influenced by the map sesnor, but map sensors rarely fail so i wouldn't assume that right off the bat.
Old Feb 20, 2008 | 01:09 PM
D-Rizzle3's Avatar
I'm tuned on chrome, obd-1, O2 sensor dissabled, no CEL, and its one of those weird lookin map sensors with 4 pins on each side and a nipple on top for vacuum...if this helps any
Old Feb 20, 2008 | 01:40 PM
red_crx's Avatar
Default Re: (D-Rizzle3)
When the map takes a dump..it will act as if no vacuum is hooked up to it. It will run super rich...foul plugs; Idle like ****, almost dieing, etc
Old Feb 20, 2008 | 02:38 PM
D-Rizzle3's Avatar
Thats exactly what its doing..thank you. Does anyone know where I can get almost like a plug and play kit or an adapter so I dont have to rig it up to something?
Old Feb 20, 2008 | 02:59 PM
red_crx's Avatar
just buy another 2.5bar map sensor...are you using the motorola map sensor?
Old Feb 20, 2008 | 03:43 PM
D-Rizzle3's Avatar
yea
Old Mar 1, 2008 | 09:51 AM
D-Rizzle3's Avatar
so i got another map sensor with the adapter plate and two days later the same **** happens again. Cant win with these things...I may just go 3bar they seem easier to work with
MatthewMenze
Engine Management and Tuning
May 1, 2014 01:24 PM
si_motor_spt
Sep 9, 2007 12:31 PM
zccr-xsi
Dec 2, 2006 06:22 AM
JSpecwest
Jan 2, 2002 12:48 PM
