Blockguard yes or no?
Done alot of searching always get conflicting opinions
GSR Block 81.5 MM on stock sleeves, after market Pistons and rods Wiseco flat tops/Eagle its at 9.5:1
Eagle Block guard installed by good machine shop Before the the cylinders were bored/ rehoned. Installed about 1/4 " below surface Welded to block
Good idea or no?
also what HP level will my Stock sleeves Be safe at?
Good idea or no?
No, useless.
Unless you do a precision fit like the CSS. Its been covered many times.
Welded to block? wtf. get a precision fitted one like the CSS or put your money elsewhere
or sleeve it.
or sleeve it.
Sorry man but you need to search....
https://www.google.co.uk/search?q=bl...&client=safari
Just place the the topic you want to know a out before "Honda-Tech" and you'll get tons of info...
http://www.cylindersupportsystem.com/
warrantied up to 500hp, just had mine done, theres a big thread on it with pictures in this forum, gotta search
