obd2B d16y8 into obd2A EK
Old May 13, 2013 | 02:55 PM
dth0ng69's Avatar
Default obd2B d16y8 into obd2A EK
Hey Guys, I'm planning on buying a swap from a friend who has a 99-00 OBD2B D16Y8 from a 99 civic ex.
I'm planning to swap it in my 1996 DX with D16Y7
He has everything except a wiring harness, I know there is alot of options i read but still getting some mix answers.
I am planning to use a 96-98 (obd2a) engine harness : things i have to do ...
1) still have to change OBD2B dizzy plugs or Use OBD2A dizzy ?
2) use OBD2A p2p ex ECU
However I am confused about the whole "air injection deal"
I'm just wondering if this is correct, I maybe missing somethings but swap gurus, what do you guys think
thanks in advance
Old May 13, 2013 | 06:56 PM
fonkernuckle's Avatar
Default Re: obd2B d16y8 into obd2A EK
Easiest but more expensive(around $125 shipped here on H-T)would be to buy the obd2a EX harness and use the obd2a dizz and obd2a P2P this is what I would do unless I have alot of time to do your first option.
I would not even consider your last option
Old May 13, 2013 | 07:02 PM
math84's Avatar
keep the ecu and harness from your civic and swap parts from the 99 engine. I'm in the same boat just the other way around. i can't find a 99 harness for my car
Old May 13, 2013 | 07:04 PM
math84's Avatar
but i just realized that your are going from a non vtec to a vtec so I'm not sure what you need
Old May 13, 2013 | 07:05 PM
dth0ng69's Avatar
Yeah, I was thinking the same thing ... I looked it up and all obd2 single cam dizzy's are the same ... so i could just use the obd2a dizz as you said.
where could I find that obd2a ex harness for $125 shipped on H-T ? the marketplace? because I don't see it ...
thanks for replying !
Old May 14, 2013 | 01:05 AM
HondaPartsHero's Avatar
Technical Hero
This
1) change IACV 3plug to 2 plug
2) use obd2A dizzy
3) Wire knock sensor, V-tec wire, some other stuff
4) use OBD2A EX ECU P2P.
Old May 18, 2013 | 08:02 AM
dth0ng69's Avatar
Originally Posted by HondaPartsHero
This
would it be that easy though ? because I heard obd2B has some type of " cold start air holes ? " on the intake manifold . and you would have to use obd2B ecu with the jumper to obd2A .
or can i still use the obd2a p2p ecu ?
Old May 18, 2013 | 08:41 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
DO NOT put an OBD2B harness in an OBD2A car, it will not work.
Old May 18, 2013 | 11:13 AM
dth0ng69's Avatar
yeah i read that they are different ... and you cannot switch it up .
I know i need to use 96-98 ex harness but what i'm mostly confused about is the air injection holes that come on 99-00 ex civic, but don't come one 96-98 civics.
here is a thread of someone with a similar thread but there are no answers as of what to do with that.
http://www.clubcivic.com/board/showthread.php?t=143846
BTW i have a complete a complete 99-00 d16y8 long block with the manifold
i read you can use the breather hose as a vacuum line but also where else do you run the injection holes for 96 obd2a ek hatch .
Old May 18, 2013 | 11:22 AM
tlarimer's Avatar
Just plug the Air injection hole, I did that when I put a 00 D16Y8 IM on my 99 D16Y7.
Just pull the nipple out of the IM flange, tap it and using thread lock, screw a plug into the hole and done.
Here is the DIY I followed:
Deleting Air injection on 99-00 D16Y8 Intake manifold
Old May 18, 2013 | 12:54 PM
Technical Hero
You don't have to do that if you have the 99-00 manifold on a 99-00 longblock, only if you are using the 90-00 Y8 manifold on a 96-98 engine. All of it is mechanical and won't effect your ECU at all. Just use the 96-98 harness and ECU.
Old May 18, 2013 | 12:57 PM
dth0ng69's Avatar
thanks for the reply, I see what you are saying.
However I have a 99-00 (obd2B) entire 16y8 long block including intake manifold. So i hear I can just just use the breather hose, hook it up to the T fitting near the thermostat and hook that up to the nipple on the intake mani (the one for the air injection) and connect that to the breather hose ....
also I hear people switching the intake manifold gasket to plug up the holes. Is plugging the holes even necessary if you have the entire long block but using 96-98 ECU and harness ? ERG .... thanks everybody for reply
Old May 18, 2013 | 01:00 PM
Technical Hero
Yes see post above
Old May 18, 2013 | 01:17 PM
dth0ng69's Avatar
oohhh i see ... you seem like you know what i'm talking about !
here is something i seen concerning the similar situation
the air injection is actually coolant temp activated. there is a switch that looks like a t-fitting on the thermostat housing that regulates it. all you need is to run some vac line from your intake tube, to the t, then out to the port on top of the intake manifold right where it meets the head. it should be completely independant of your ecu and just have to be routed to work. "
so would i have to get custom lines to get all these vacuum lines connected ?
Old May 18, 2013 | 02:09 PM
Technical Hero
If it doesn't have them them just "T" off a vacuum fitting of similar size and connect the other end to the manifold port like the photo above.
HotrodHooptie
Jan 6, 2018 02:59 AM
Wrench6
18
Jul 4, 2015 10:50 AM
sMoKe_RoCkS
Jun 25, 2008 12:50 PM
goat442003
Jun 21, 2003 07:16 PM
Ransom
Aug 29, 2002 07:11 PM
