d16y8 swap trouble
Old Jun 24, 2008 | 08:11 AM
sMoKe_RoCkS's Avatar
Default d16y8 swap trouble
Here the deal i have a d16y8 swap with complete wiring harness and ecu from a 2000 civic ex. My car is a 98 civic DX hatch. i have dont the swap and i have some issue's, here they are Tach is not working, speedo is not working, reverse lights dont work, a/c compressor runs continuosly even though a/c switches are off. anyone else have this problem?
Old Jun 24, 2008 | 10:14 AM
inspyral's Avatar
If I recall correctly, 96-98 and 99-00 harnesses aren't 100% interchangeable, so that might be where your problem lies. You could've used a 96-98 VTEC harness, or just used your original harness and added the VTEC and knock sensor wires.
Old Jun 24, 2008 | 10:51 AM
Default Re: (inspyral)
AAAAAAAha dang it ok thanks for the info im gona swap the old harness back in and add the sensors. O would i have to use a 98 v-tech ECU?
Old Jun 24, 2008 | 12:22 PM
inspyral's Avatar
You can do that, or you can get an OBD-IIA>OBD-IIB adapter harness to run the 99-00 ECU.
Old Jun 24, 2008 | 02:52 PM
kommon_sense's Avatar
You can use the harness from http://www.boomslang.us or you can buy my d16y8 5spd ecu from my 98ex. Shoot me an IM if interested.
Old Jun 25, 2008 | 12:50 PM
cOO.... thanks alot fellas, i think im gona get a 96-98 harness and then go with the boomslang adapter harness.
HotrodHooptie
Jan 6, 2018 02:59 AM
Wrench6
18
Jul 4, 2015 10:50 AM
Eaglekper0046
Sep 27, 2005 09:41 AM
goat442003
Jun 21, 2003 07:16 PM
