EJ6/B16 swap - transmission noise, CEL codes, and speedo issues
Old May 6, 2013 | 08:14 PM
EJ6_OB's Avatar
Default EJ6/B16 swap - transmission noise, CEL codes, and speedo issues
I just recently swapped a b16 into my ej6 and having some problems.
when started the engine makes a weird whirling noise like how it were to sound
if powersteering fluid was out. The noise would than stop if i step on clutch...
i than tried the shift linkage and 4th gear is locked out? idk how it would be because i just installed a
new clutch...maybe tranny is ****** up? (yes there is fluid in the tranny)
lastly i tooked it out for a drive(going only 30mph) the engine stalls and bogs at 2000-3500 RPM ...
while on the road the spedometor was acting crazy and moving up and down before it died and stopped working..
i checked the codes and got a code 2 and code 5...(which shouldnt have killed the spedometor) for a P28 ecu
so i switched it to a P30 and got readings of only code 2 but with really really low idle posslibly 200(still bogging and stalling)
I need some expertise HT!
http://www.youtube.com/watch?v=QCQic...ature=youtu.be
Old May 6, 2013 | 08:18 PM
B_Swapped93's Avatar
Default Re: B16 issues
can you get a vid ? code 2 is Oxygen content B and #5 I can't seem to find obd1 or 2 ?
Old May 6, 2013 | 08:26 PM
EJ6_OB's Avatar
I think code 5 might be the base map? should i reset the ecu for that..........but if anything i'll try and get a vid up tomorrow.
Old May 6, 2013 | 08:37 PM
obd1 right ? http://check-engine-light-codes.blog...retrieval.html
if not ignore that^
you can try re-setting it but #5 doesn't exsist at least not that I know of
Old May 6, 2013 | 08:43 PM
EJ6_OB's Avatar
are you sure? it says here
Code 3 and 5 Manifold Absolute Pressure ...
Old May 6, 2013 | 08:48 PM
im too tired haha ok Manifold Absolute Pressure aka MAP sensor a bad one of those car really mess with your engine are you running rich (check plugs) if so that can contribute to the bogging at lower rpms
Old May 6, 2013 | 10:15 PM
Former User's Avatar
Sounds like a bad transmission main bearing, typically the input shaft bearing. You may also have a bad gear synchro. Have you checked whether the transmission has any fluid in it?
Code 2? Are you sure it's not code 20? Post a video.
Also check whether 7.5A dash fuse 15 is blown.
Old May 7, 2013 | 08:25 AM
EJ6_OB's Avatar
Default Re: EJ6/B16 swap - transmission noise, CEL codes, and speedo issues
yes i refilled the fluid before i ran her up.
and i just checked all the fuses..and they seem to be in good shape.
Old May 7, 2013 | 08:26 AM
EJ6_OB's Avatar
well i just uploaded an video. The link is below
Old May 7, 2013 | 08:48 AM
Codes 20 (ELD) and 41 (primary O2 sensor heater)
Reset the ECU to clear the codes - do they both return?
Start by voltage testing 7.5A dash fuse 15 - click Fuses link in my signature.
Old May 7, 2013 | 08:50 AM
EJ6_OB's Avatar
I wasnt sure on how to read them....but i dont think that would cause the speedo to die out right?!
Old May 7, 2013 | 08:54 AM
EJ6_OB's Avatar
Where do you think the noise is coming from?
Old May 7, 2013 | 08:56 AM
Old May 7, 2013 | 08:59 AM
EJ6_OB's Avatar
could that be a reason why 4th gear wont go into place?
Old May 7, 2013 | 09:01 AM
It would help if you took just a moment to read and comprehend responses in your thread.
Old May 14, 2013 | 04:32 PM
EJ6_OB's Avatar
I just realized that my buddy has a free b17 tranny i was wondering if the parts are
interchangable?
shadowbay22
Feb 7, 2019 10:16 AM
trat 5151
Honda Civic (2001 - 2005)
Jul 13, 2017 07:21 AM
civicmark
May 28, 2004 08:34 PM
