fuel pump main relay
Old Oct 23, 2002 | 02:08 AM
budlight's Avatar
Default fuel pump main relay
the fuel pump is powered by a main relay, im confused on what a main relay is and how it works. thanks
Old Oct 23, 2002 | 02:36 AM
kinesistech's Avatar
Default Re: fuel pump main relay (budlight)
The main relay gives power to the ecu and fuel pump depneding on ignition switch position. When the key is in the ign2 position it gives momentary power to the pump to prime the fuel system with pressure. When the engine is running it gives ign power to the pump and ecu. When the key is off, there is no power.
Old Oct 23, 2002 | 06:59 AM
EE_Chris's Avatar
HowStuffWorks has a nice article on relay operation.
Old Oct 23, 2002 | 01:48 PM
Perfectionist's Avatar
There are two parts to the main relay. One half powers the fuel pump when the ignition is turned on. (The ECU limits this to about 2 seconds until the engine is running) The other part provides power to the fuel injectors.
Old Oct 23, 2002 | 10:52 PM
budlight's Avatar
Default Re: fuel pump main relay (Perfectionist)
so, there are two switches in the honda / acura main relay one for the fuel pump and one for the injectors. is this main relay located in the fuse box?
are there any other relays in the car?
Old Oct 23, 2002 | 11:48 PM
Relays are just switches that can hold high current. They are used for all kinds of circuits. Cooling fans to rear window defrosters. Its not in the fuse box, there are a couple locations Honda like to put them depending on the car.
Old Oct 24, 2002 | 07:02 AM
Shft@9GSR's Avatar
Default Re: fuel pump main relay (kinesistech)
I know sometimes the PGM relay is located behind the kick panel on the driver side (behind hood release). I also know that these do tend to fail after long periods of time. At least on the older CRX's.
Problem is usually intermittant. Usually no fuel pump kicking when the key is turned on.
But yes the PGM relay either has 2 or 3 sets of contacts inside.
Old Oct 24, 2002 | 07:10 AM
sackdz's Avatar
Default Re: fuel pump main relay (Shft@9GSR)
Indeed, and mine left me stranded a few times till I figured out what it was. Resoldered the leads and all is well.
On 99-00 civics, this relay is behind the side dash cover on the passenger side.
Old Aug 22, 2003 | 10:03 AM
garagespecial
Guest
Posts: n/a
Default Re: fuel pump main relay (sackdz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">&lt;BLOCKQUOTE&gt;quote:&lt;HR&gt;I know sometimes the PGM relay is located behind the kick panel on the driver side (behind hood release). I also know that these do tend to fail after long periods of time. At least on the older CRX's.
&lt;HR&gt;&lt;/BLOCKQUOTE&gt;
On 99-00 civics, this relay is behind the side dash cover on the passenger side. </TD></TR></TABLE>
correction - 99-00 civic, located on the drivers side mounted on the chasis with a 10mm bolt
slowEGles
May 13, 2013 06:16 PM
3easy21
Jun 11, 2012 07:27 PM
dszer89
Jul 22, 2010 04:41 PM
Domnificent
Jul 11, 2010 10:29 AM
Steve
Aug 29, 2001 06:38 PM
