Problems with LS swap on EJ2
Old Apr 23, 2013 | 12:52 PM
gummer88's Avatar
Default Problems with LS swap on EJ2
////UPDATE AT BOTTOM OF THIS POST (NEW PROBLEM, HELP!!!!!!!)////
Hi, I'm doing a 95 ls swap on my 93 civic, it used to have a D15B7, the ls motor came without harness, so I tough I could use the harness from the d15 since both are obd1, but everything plugs fine except for the injectors, they don't fit.
This is the injector from d15:
And this is from the b18:
As you can see the d15 injectors are more squared, and the b18 are rounded.
Also the d15 has a little tab centered, and b18 has a bigger tab and is loaded to the right.
What can I do?
Can I use the injectors from d15 on b18? is safe or I will be running poor mixture?
Or should I stay with injector from b18 and get the engine harness?
////////////////////////////////////UPDATE////////////////////////////////// HELP!!!!!!!!!!!!!!
Now I have new problems:
-The engine is installed, it starts fine and stays at 700-800 rpm for a few seconds then the rpm's drop to below 500, and it seem like it is gonna die
-I have checked all sensors and connectors, everything is fine
-Checked for vacuum leaks and nothing, screwed and unscrewed the screw at the top of the throttle body without any change
-Tried to adjust timing but I can't get it to 16 grades, I advanced the time all the way the distributor let me, it got better but still under 500 rpm's.
-No misfire, just very low idle and seems like it would die but it didn't.
-If I hit quickly the gas it revs fine.
Now I don't know what else to do; if you could help me I would appreciate it
Old Apr 23, 2013 | 01:28 PM
EFfin Sedan 91's Avatar
Default Re: Problems with LS swap on EJ2
This should answer your question:
http://hondaswap.com/general-tech-ar...-flow-rates-6/
Old Apr 23, 2013 | 01:30 PM
94EG8's Avatar
Seagull Management
The B18 has OBD2 injectors. Swap over the D15B7 injectors, they're both 240cc.
Old Apr 23, 2013 | 01:47 PM
gummer88's Avatar
Originally Posted by EFfin Sedan 91
Ok, that's what I found on that page:
All obd 1/2 B series are 240cc's saturated
All obd 1/2 D series are 240-cc's saturated
I wasn't sure about each rate, but with that info now I know it is completely safe to swap them.
Thank you so much, I thought was on mayor problems, and didn't found an answer on web.
I will save that reference page for future problems
Old Apr 23, 2013 | 03:24 PM
Marvin1985's Avatar
WRONG NOT ALL D SERIES INJECTORS ARE 240cc some are 190CC!!!
Old Apr 23, 2013 | 03:25 PM
Marvin1985's Avatar
Get injector harness adapters. Don't half *** that ****
Old Apr 23, 2013 | 03:41 PM
94EG8's Avatar
Seagull Management
That's true, D15B8, D15Z1 and D16Y7 are all either 180 or 190CC.
There's nothing half assed about running the correct injectors. D15B7 injectors are 240CC the same as B-series injectors.
Old Apr 23, 2013 | 03:47 PM
Marvin1985's Avatar
Probly the best chart to follow. And yes that's not half ***, but the information was wrong. That was my main argument
http://www.phearable.net/tech/stockinjectorsizes.html
Old May 1, 2013 | 04:28 PM
gummer88's Avatar
Old May 2, 2013 | 11:38 AM
gummer88's Avatar
Last night cleaned the IAC and it helped just a little insignificantly, also noticed that if I hit the gas quickly it revs, but if I keep the gas the revs go up but then starts to drop at the point that it starts to die.
Today checked mechanical time, I think it is out but I'm not sure.
Lower pulley was aligned on the TDC mark, but upper pulleys don't look horizontal:
Is exhaust side out by one thoot? Or are both out?
Old May 2, 2013 | 11:52 AM
kyden's Avatar
they look ok to me. if you look you can see both marks on the cams are lined up.
Old May 2, 2013 | 02:35 PM
gummer88's Avatar
I re-checked the mechanical timing, it is fine, even when the upper pulleys seems not to be aligned the side marks are aligned side by side, I'm frustrated I don't know what else to do
Old May 2, 2013 | 02:55 PM
cruizinmax's Avatar
If you can't get the ignition timing correct there is something wrong. You need to find out why.
Old May 3, 2013 | 05:13 AM
kyden's Avatar
what ecu are you using? any codes?
Old May 3, 2013 | 05:41 AM
sleepyaccord96's Avatar
you need to add a nut to your motor mount. in that pic it has 2 studs and i only see one nut. thats gonna cause a problem within itself.
check the throttle cable tension and you may end up adjusting the idle via the idle screw adjuster.
Old May 3, 2013 | 07:10 AM
h22steaksauce's Avatar
Sounds like map and tps plugs are mixed up. It'll give u a low idle
Old May 3, 2013 | 08:49 AM
eg6gsref9b20v's Avatar
Has to be map and tps the plugs are the same Lol and right next to each other also that one but thing is crazy fix that do not drive it like that! Also its just basically process of elimination go through everything and find the cause.
Old May 3, 2013 | 09:39 AM
gummer88's Avatar
Chipped p28, no cel's
I have present the fact of the nut, will check the tension on the cable, but really don't think it will make a difference, since it is supposed to be tight but not open the throttle to get air, but I will try it anyway
I marked the sensor connectors but anyway I will give it a try
Old May 3, 2013 | 10:48 AM
gummer88's Avatar
I have checked all sensors, I had them marked since before the swap, however I swapped the connectors between IAT and purge solenoid, and between TPS and MAP sensors, both giving me worst results, so I switched them back.
Also it doesn't have the purge solenoid on the top of the maniful so I put a plug on the hole and canister hoses aren't connected.
Old May 3, 2013 | 10:49 AM
Former User's Avatar
^Very risky test that can blow the ECU.
Old May 3, 2013 | 11:32 AM
gummer88's Avatar
Won't do it again
Old May 4, 2013 | 09:19 AM
gummer88's Avatar
I don't know if that was because I switched the sensors, but today opened the ecu and one element is blown, I will better get the right ecu for the LS
Old May 24, 2013 | 01:13 PM
gummer88's Avatar
Problem solved finally, yesterday arrived a new ecu with the right map for the ls, it runs smooth, no cel's, timing is right, everything is fine, I'm so happy there are no more problems.
This thread can be closed, thanks to everyone for the help!!!
Ek9Kiddo
Sep 5, 2010 12:04 PM
93sihatchy
11
Jun 10, 2007 03:40 PM
Turbo_Mike
Feb 20, 2006 12:36 PM
Orangedragone
Oct 27, 2005 08:04 AM
