antifreeze overflow tank problem.
Old Apr 16, 2013 | 06:18 AM
tealej2's Avatar
Default antifreeze overflow tank problem.
I bought a ej2 and i noticed the overflow tank was dirty. I open my radiator cap and pressure comes up from the overflow. My radiator also has some funny lookin brownish stuff inside it. I bought a new radiator n cap n still the samething. I havent had a problem with temp n never over heats but what can it be
Old Apr 16, 2013 | 06:32 AM
B_Swapped93's Avatar
Default Re: antifreeze overflow tank problem.
The "brownwish stuff" is probably oil. Flush you'r rad,refill then bleed it drive it for day or so see if it comes back.
Old Apr 16, 2013 | 06:53 AM
tealej2's Avatar
Will try that. Any other ideas. I will try n get a pic for better review
Old Apr 16, 2013 | 07:52 AM
TIMMY4TOES's Avatar
If it has that "brown stuff", more than likely your head gasket is going out. try what the second post said first. Good luck
Old Apr 16, 2013 | 10:05 AM
tealej2's Avatar
Its been like that for alittle while and i did a full tune up including head gasket.
Old Apr 16, 2013 | 10:33 AM
98civdx's Avatar
Master Detailer
When you did all that, did you flush the cooling system?
Either way you need to flush it now.
Old Apr 16, 2013 | 12:20 PM
xile6's Avatar
As everyone said.
Once flush check and see if your losing coolant or filling up the over flow.
If so its more or less a headgasket. Just delt with this a few weeks ago.
Old Apr 16, 2013 | 12:28 PM
strategy400's Avatar
Could just be neglect/plugged/rusted radiator. If so radiators are cheap.
Old Apr 16, 2013 | 01:17 PM
TIMMY4TOES's Avatar
true, if you just did the head gasket. I would recommend doing a flush or changing the rad and then flushing.
Old Apr 16, 2013 | 01:31 PM
tealej2's Avatar
Did a flush when i bought a new radiator and cap.
Old Apr 16, 2013 | 01:39 PM
tealej2's Avatar
This is whats going on. Dont know what the hell it is.
Old Apr 16, 2013 | 02:08 PM
TIMMY4TOES's Avatar
I would say its the head gasket. there is no way there can be that much sludge in there.
Old Apr 16, 2013 | 02:16 PM
POPLERO's Avatar
head gasket moat likely
Old Apr 16, 2013 | 02:17 PM
tealej2's Avatar
Confused. Man did a gasket when i did a full tune up when i got the new cap and rad. Some1 said it could be a waterpump issue?
Old Apr 16, 2013 | 02:18 PM
b20bFourDoorCivicLX's Avatar
that is bad . good luck i would fix asap!
Old Apr 16, 2013 | 02:22 PM
tealej2's Avatar
Thanks. The problem is its happen before. Like i said i did a flush a full tune n gasket job new rad and cap. N now its backk.fml
Old Apr 16, 2013 | 02:33 PM
TIMMY4TOES's Avatar
yeah, i never seen a water pump do that. gl
Old Apr 16, 2013 | 02:34 PM
TIMMY4TOES's Avatar
it looks like your head or blocked is super warped. thats why it keeps on coming back.
Old Apr 16, 2013 | 04:37 PM
tealej2's Avatar
Well i been thinkin bout a swap so mayb its coming soon
Old Apr 16, 2013 | 04:46 PM
98civdx's Avatar
Master Detailer
Damn, i've never seen it that bad!
Shine a light into the valve cover and see what it's looking like under there. Or just pull it off.
Old Apr 17, 2013 | 04:06 AM
xile6's Avatar
flush the hg dye kit. that will give you your answer.
Old Apr 17, 2013 | 11:57 AM
Could be residual from the previous bad headgasket. Oil floats so it's going to find its way to the upper radiator tank. Also, if oil got in your coolant all the hoses may start to deteriorate. Rubber and petroleum products don't mesh well unless they were designed for that purpose. A set of all the hoses for your car can be had at the Honda dealer for a reasonable price. You may want to verify that your headgasket is intact before investing in any ancillary parts.
Old Apr 17, 2013 | 01:19 PM
TIMMY4TOES's Avatar
Maybe, but honestly have you checked if the car is burning oil or water vice versa?
Old Apr 17, 2013 | 05:04 PM
xile6's Avatar
did you reuse the old head bolts? and what did you t1 it down to?
panchlow
Jun 29, 2010 05:37 PM
Cripton805
Nov 18, 2009 11:49 AM
bark3rk20
23
Apr 18, 2009 09:25 PM
dynastix9
Dec 18, 2005 06:33 AM
B17AGSR
Jun 8, 2004 07:23 AM
