Severe Oil Leak
After doing a headgasket replacement on my brother's '96 Civic EX sedan, oil pours down the back of the engine and onto the driverside inner axles and makes decent size pool underneath, and down onto the tranny. I noticed oil pooled up quick where the VTEC solenoid bolts up to the head. I hope that is it. I did not remove the solenoid either, and it started pouring out as soon as the car starts up. I really hope it's not the headgasket as it is brand new. It doesn't overheat or anything after the replacement, just the oil leak. It was yesterday and no Honda dealers would be open, so I told him to check his oil each time he drives.
I properly detorque and followed the torque in sequence given by All Data:
1st step: (1) - (10) 20 Nm (2.0 kgs.cm, 14 ft.lbs.)
2nd step: (1) - (10) Nm (5.0 kgs.cm, 36 ft.lbs.)
3rd step: (1) - (10) Nm (6.8 kgs.cm, 49 ft.lbs.)
4th step: (1), (2) Nm (6.8 kgs.cm, 49 ft.lbs.)
Anybody have this happen to them before?
Did you put the HG on upside down ? yes it's possible I did it once had a HUGE leak lost 70% of my oil in the first couple mins of start up. was a B18C1 tho. did you seriously tell/let him drive with an oil leak like that
it will leak even more when the car is driving vs idleing coolant loss with cause the car to overheat(vissably via the temp gauge) have you seen a car run dry from oil loss no real indication if it's a leak and all pours out. if i had driven with my leak i'd be dry before i got 2km's down the road
it will leak even more when the car is driving vs idleingAnd no, I did not put the headgasket upside down. I made sure it goes on the same as the old HG. All the oil galley and coolant passages match up to the new HG as well.
Going there after my appt to replace that VTEC solenoid gasket.
Thats his only car and he has to get to work, so he has no choice. It drips constantly but not to where it rushes down like a stream.
Yeah, he overheated. The coolant resevoir was milky as fudge and keeps loosing coolant. I noticed that coolant has been going into the combustion chamber cause some part of the top of pistons were white. Same with the valve faces.
sounds like the head or block could be warped. did you check them(at least the head) before you replaced the HG i know it's his DD but if the HG is on the right way and you TQ the head to spec there shouldn't be oil leaking did you replace/do anything else that could cause a leak or just the HG
Then the VTEC solnoid started pouring out. So I'm gonna replace that tonight.
I believe I got it fixed.
We bought a VTEC solenoid filter screen o-ring and thought it was that, but it's not just as I figured it was gonna be the middle o-ring that's sandwich between the upper and lower solenoid. Thats where it was pouring out of. Honda does not show them selling it by itself as you have to get the whole VTEC assembly. But Honda sells them o-ring separately for the 95 and lower Civic which he does not have in stock. So I hit up my brother-in-law to see if he's got one laying around; since, I know he modifies Civic left to right. And sure enough, he does. Has a D16z6 long block chilling outside. I grabbed that VTEC Solenoid and used it on my bro's D16Y8 and no more leaking.
My local Honda has those middle o-ring in stock tomorrow, so I'll be sure to grab them for his car.
Dowel pins were both removed from the head and put back onto the block, so it can keep the new HG aligned.
Thank for all the replies.
What do you mean? The VTEC solenoid bolts up fine and does not leak. Like I said before, the new Y8 filter screen even goes on fine with the solenoid we picked up. As long as it doesn't leak til the new o-ring gets here, we're gonna slap his old one back on. Just so he can get to and back from work. Like I said, it's not his VTAK warrior.
EDIT: Just confirmed with my in-law that it is indeed a z6 block, but it has y8 head swap. Now it all make sense.
I've got 227k on my'99 EX and need to replace the distributor o-ring & vtec solenoid gasket too. Just picked it up used. I'm guessing they were overdue before I bought it. Appreciate the info here. I paid my mechanic to diagnose it & now I get to fix it. So much for a Sunday off.
Never put a Honda head back on without a resurface...it won't last long. It only takes 3-4 thousandths on a honda to be out of tolerance. Best of luck w/that. What the hell is VTAK, yo?
