why you no work vtec?
Old Apr 7, 2013 | 01:25 PM
keith1993may's Avatar
Default why you no work vtec?
im pretty sure theres a thread somewhere about this. but was wondering why my vtec isnt kicking in. i have no CEL. running a ls block with a gsr head. p75 on crome. cant think of why it isnt working. . i could record a video if necessary.
Old Apr 7, 2013 | 01:26 PM
grumblemarc's Avatar
The Grumpiest
Default Re: why you no work vtec?
If you can rev to redline it's working.
But then again since Civics never came with LS engines with GSR heads this probably should have been posted in the Hybrid forum.
Old Apr 7, 2013 | 01:42 PM
mattyfo0z's Avatar
have you checked your oil? low oil pressure will prevent vtec from engaging. being as you have an ls/vtec setup where you have to run an additional oil line, that would be my first thing to rule out.
Old Apr 7, 2013 | 01:46 PM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
Old Apr 7, 2013 | 02:09 PM
oil level is fine. i do have a few sensors unplugged. ill take a pic of the heads of them. if the oil pressure sensor isnt hooked up would that cause it?
Old Apr 7, 2013 | 02:12 PM
The Grumpiest
OMG. Y'think?
Information that was left out of the first post.
Why do people post up issues when they KNOW there are deficiencies that they need to take care of?
Old Apr 7, 2013 | 02:17 PM
Technical Hero
The engine oil pressure sensor won't affect it but the VTEC pressure switch will. Post your codes.
Old Apr 7, 2013 | 02:22 PM
B_Swapped93's Avatar
true but i'll be he's talking about the vtec pressue switch thus no vtec
Old Apr 7, 2013 | 02:24 PM
im not sure what sensors are unplugged. gimme 5 minutes and ill post pics
Old Apr 7, 2013 | 02:35 PM
Old Apr 7, 2013 | 10:47 PM
jonsey1886's Avatar
10 Year Member
One of those I'm almost positive is ABS (the one with the white endcap on it) the other I dunno off hand.
The larger one I know for certain because I also have it on my car....capped like that as I don't have ABS on my vehicle.
Old Apr 8, 2013 | 01:30 AM
Technical Hero
Top looks like reverse light switch. Bottom is for oxygen sensor. Pull your check engine codes and post them.
Old Apr 8, 2013 | 06:52 AM
kyden's Avatar
does your p75 have the vtec components added to the board?
Old Apr 8, 2013 | 07:25 AM
it should.. i didnt put the swap together so i dont know for certain but i willask the guy who did
lsvtec1.9lcrx
17
Dec 15, 2005 04:47 PM
lemongreenhatch
Jun 26, 2004 07:24 AM
lemongreenhatch
Jun 23, 2004 07:02 PM
highcomp
Feb 9, 2004 12:32 AM
b20b
Feb 22, 2002 03:42 AM
