T3 vs T3/T04e
Old Oct 22, 2002 | 02:01 PM
kshymkiw's Avatar
Default T3 vs T3/T04e
What is the difference between just the T3 and the T3/T04e?
Old Oct 22, 2002 | 02:24 PM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: T3 vs T3/T04e (kshymkiw)
the T3 uses the smaller TB03 compressor housing, wheel and backing plate.
the T3/TO4E uses the larger TO4E compressor housing, wheel and backing plate, along with the TB03 turbine.
to give an example
compressor flow rate on the TB03 compressor 60 trim wheel .60 a/r is 35 lbs/min
compressor flow rate on the TO4E compressor 60 trim wheel .60 a/r is 53 lbs/min
hope this helps
Old Oct 22, 2002 | 04:26 PM
shadowdawn's Avatar
Default Re: T3 vs T3/T04e (CHEAPTURBOdotCOM)
t3/t4e watercooled owns my soul!!!! MAJESTIC GIVE ME IT BACK ALREADY!!!! hating waiting even if its only a few days
Old Oct 22, 2002 | 05:11 PM
kshymkiw's Avatar
Default Re: T3 vs T3/T04e (shadowdawn)
SO what is watercooled? If you have a water cooled turbo do you still need an intercooler? Sorry i have never heard of a water cooled turbo
Old Oct 22, 2002 | 05:17 PM
inspyral's Avatar
A water-cooled turbo has boil oil and water/coolant running thru the CHRA. The coolant helps cool the turbo, and prolongs the life of the turbo.
Old Oct 22, 2002 | 05:57 PM
shadowdawn's Avatar
Default Re: T3 vs T3/T04e (inspyral)
Yep he explained it best.... coolant AND oil flow thru the center section to cool things down, prolongs life and can cool down less after hard runs... its a beautiful thing
Old Oct 22, 2002 | 06:45 PM
turbo Si's Avatar
Is the T3/T04e the same turbo in the Drag III kits?
Old Oct 22, 2002 | 06:59 PM
shadowdawn's Avatar
Default Re: T3 vs T3/T04e (turbo Si)
most drag kits come with the b which is smaller.... some come with the e.... their kits aren't very concrete when it comes to the turbo
For a b16 a b would be fine as its for 1.5 to 1.7 motors, e is generally for 1.7 to 1.9 unless you get a .49 or whatever trim turbine.
Old Oct 23, 2002 | 02:07 AM
kshymkiw's Avatar
So you still need that damn intercooler huh?
doc
Nov 8, 2005 07:26 AM
B18c1turboedEK
Nov 24, 2004 10:56 PM
Honda Sport
Jul 16, 2004 04:58 PM
ls-t del sol
Feb 22, 2003 01:36 PM
Dorikamu
May 3, 2002 07:17 PM
