help with neptune rtp demon, set up 2 step
i just traded hondas with someone. the car that i just got is turbo'd and has been tuned with neptune rtp demon. i have setup my laptop to connect with the software. the only thing i want to do is use the 2 step feature, but it wont allow me to click on anything under the 2 step feature window. also, is there a way to pull of the maps that the car is running on? i have succesfully adjusted 2 step with hondata s300 in the past and i understand how to use it, its just i cant click on anything or input any numbers in the boxes
thank you, its working haha. one last question if you read this again...this car hits 15 pounds of boost, but has a honda stock map, with no cel, and on neptune, the map reading has no value...how is this possible
The stock map sensor can't see 15psi so you're already hurting the engine as far as tuning goes.
Until you have a tune open it doesn't know what map sensor you have selected, so it can't display anything.
