taking off 3 bar map, tuning issues help!!!!!!!
Old Dec 6, 2003 | 10:52 PM
hybridb18's Avatar
Default taking off 3 bar map, tuning issues help!!!!!!!
ok, so i have my car tuned on an afc hack with the 3 bar map hooked up. But i have decided to take off the 3 bar and put the stock map back on (cause im only running 10 lbs).
So anyway, i have the afc set to 14 in and 14 out. but when i put the stock sensor back on, im gonna have to put it back to 6 in 6 out. this is gonna **** with the fuel settings.
Is there anyway i can just set it to like 6 in and 14 out, and keep the same fuel settings?
Pretty much i just dont feel like retuning this crap, and im trying to find a way around it. anybody have any ideas?
Old Dec 7, 2003 | 11:40 AM
hybridb18's Avatar
Default Re: taking off 3 bar map, tuning issues help!!!!!!! (hybridb18)
ttt
Old Dec 7, 2003 | 12:14 PM
hybridb18's Avatar
ttt1
Old Dec 7, 2003 | 01:07 PM
Del_Slowest's Avatar
nope, when you set the 6 in and 6 out crap it's telling it's a honda map sensor going in and a honda map sensor going out. the 14 in is saying its a GM. Ya can't mix and match numbers
Also, it won't mess with ur fuel settings. Worst thing that happens is that you get a CEL b/c of ur map sensor seeing boost but with 10psi and no creep it'll be okay.
However, if your fuel setting were tuned for something other than 10psi then you're ******. If your fuel settings were tuned for 10psi in the first place then it's no problem, just switch out the map sensors and ur good to go
sdbee84
Jan 31, 2016 11:20 AM
projectjazzmine
Engine Management and Tuning
Jun 10, 2008 09:38 AM
ekk41
Oct 24, 2007 05:28 PM
sleeprhatch
Sep 23, 2006 12:04 PM
