My Honda Civic 1999 Overheats when driving over 65MPH during the day
Old Apr 2, 2013 | 09:55 AM
cpena's Avatar
Default My Honda Civic 1999 Overheats when driving over 65MPH during the day
I've been having this issue for some time now.. i have replaced the radiator and the problems continues. this would only happen during the day.. here in Belize the weather is very hot during the day. this problem does not happens at night. my car runs nice during the night. PLEASE ADVICE.. as i said this only happens during the day when i am driving far and the sun is hot. i would never allow for the temperature gauge to go over 3/4. i would always be monitoring the temperature gauge so it would only go a little above half.. In the city it drives nice.. this problem only happens when driving at fast speeds
Old Apr 2, 2013 | 10:37 AM
EJ8_Man's Avatar
Default Re: My Honda Civic 1999 Overheats when driving over 65MPH during the day
You replaced the radiator, did you also replace the thermostat?
Old Apr 2, 2013 | 11:20 AM
cpena's Avatar
i already order it so i'll replace it as soon as i get it.. what do u think might be causing this overheating?
Old Apr 2, 2013 | 11:36 AM
EJ8_Man's Avatar
My guess is a bad thermostat that is not opening all the way
Old Jul 9, 2013 | 12:47 PM
cpena's Avatar
i did replaced the thermostat and it still continues to run hot.. One mechanic is telling that it can be the water pump and the other is telling me that the radiator needs to be flushed.. Any suggestions as to what the problem could be??
Old Jul 9, 2013 | 02:48 PM
purgat0ry's Avatar
If your impeller is pretty worn out / eaten away, I'd imagine it would make a difference, but I'm no expert.
When was the last time the water pump was serviced?
Old Jul 9, 2013 | 04:10 PM
Merkle's Avatar
I'd check your water pump for starters. Check the fluid level, your radiator cap and hoses. See if you can do a pressure test as well.
I had a bad thermostat on my 1996 EX and at speed there was enough air moving to cool the engine, but, when slowing down it would begin to heat up. You have the exact opposite of this problem. A quick way to test the thermostat is the upper hose will be hot and the lower hose only lukewarm.
Old Jul 9, 2013 | 05:23 PM
HondaPartsHero's Avatar
Technical Hero
Does your cooling fan work?
Orangevirus1's Avatar
inadequate ducting.
lazychina
Jun 22, 2011 05:22 AM
miszjackie
Honda Civic (2001 - 2005)
Dec 23, 2009 07:33 PM
kitteekate
May 16, 2008 05:37 PM
DaveSi677
Jul 5, 2006 10:35 AM
JDMlyfestyle
32
Jan 14, 2004 01:53 PM
