Divided manifold collector
Old Apr 1, 2013 | 11:25 AM
vtechjunkie's Avatar
Default Divided manifold collector
I have been looking around for collectors, and I can find a ton, but I haven't found any for a divided manifolds. I have made my own manifold before, but never a divided. I am curious to see what you guys are doing for your collectors. Also what processes you guys find to work best for you. Thanks!
Old Apr 2, 2013 | 03:08 AM
that-guy's Avatar
Default Re: Divided manifold collector
measure the opening of each port to figure how far spread they need to be, create the angle your comfortable with, and weld it up
Old Apr 2, 2013 | 09:42 AM
I can jump in and figure that much out, but I was hoping for a "I like to use _* angle for a ramhorn, and if I have the space I tweak it" type of response.
Old Apr 2, 2013 | 11:45 AM
SovXietday's Avatar
I would suggest not making a ramhorn divided, if that's what you're asking lol.
Old Apr 2, 2013 | 01:08 PM
No! LOL! I was just using it as an example.
Old Apr 2, 2013 | 08:32 PM
SovXietday's Avatar
I think I did a 13* collector split with like a 10* offset on my manifold. Did it so long ago at this point I don't remember.
Wasn't super easy getting in between on it but I managed. Honestly, easiest collector I ever built.
Old Apr 7, 2013 | 09:58 AM
On the collector, the one side is easy, I can see that. The other side now, that looks like it'll be a bit more technical. Are you welding it from the bottom of the flange? If not, how are you managing to get the seam welded down in there without arcing to the side of one of the walls first?
Old Apr 7, 2013 | 01:54 PM
a1320honda's Avatar
Made my own divided T4 collector. I used 15* for each divided side. Then just used a belt sander for the insides.
Old Apr 8, 2013 | 09:07 AM
SovXietday's Avatar
Yes, I welded the middle from inside of the flange. You can fill it but it doesn't really work that well if the angle is too narrow.
Old Apr 9, 2013 | 10:14 AM
I was thinking the same thing. Thanks for the advise!
Old Apr 11, 2013 | 12:10 PM
Ron @ RLD helped a brother out. At the price I got it, it was way more economical to just buy it. I'll be doing the same for all collectors now. If nothing else, just the saw blades, and time saved will be more than worth it! Thanks Ron!
gehlSRT
Welding / Fabrication
Oct 11, 2011 09:34 AM
azandford
Nov 27, 2009 10:55 AM
nebulight
Nov 13, 2004 01:44 PM
Blindstuff
Oct 5, 2004 06:33 PM
