what pcv valve?
so ive tried a ls and a gsr pcv valve on my lsv with ls block and gsr head. both seem to be too big. they wont go in. anybody have an idea to what i can use? is the b16 a smaller one? could i just use it in replace of it? or could there be something wrong with my canister
they're not that easy to push in, try dipping your finger tip in some oil or use the end of the dipstick to lube up the PCV then try pushing it in. it should go in now
I did a little research on this and from what I found all B & D series are all the same. same size same part # everything. Did you try the oil? when I did mine the old one would just fall out couldn't get it to say in, and the new one for the life of me would NOT go in. If I remember correctly I did end up having to take the intake manni off again and I used a little bit of oil off the dipstick to get the PCV back it. wiggle and twist it will go in. maybe try channel locks or pliers to help push it in so you're not stabbing you hand with the plastic, just dont squeeze and mar it up.
aleks77
Sep 4, 2008 09:35 PM
