confused on pcv on ls/vtec....need help
Old May 3, 2005 | 07:33 PM
boost fed ls's Avatar
Default confused on pcv on ls/vtec....need help
I have reading for the last 2 hours and I just can't seem to figure this. I am just going to have to ask it in my words and see if some one can explain it to me.
I just built a ls/vtec motor using a 98 bottom end. We all know that this year ls block had the pcv valve located in the valve cover and the gsr pcv valve is loacted in the black box on the back of the block. Since my gsr head has no port for a pcv valve and only a breather vent, can I just hook a tube from the berather vent to a catch-can to the intake mani and be done with the pcv valve or do I have to drill into my valve cover and install a pcv valve that will connect to the intake mani and put a filter on the breather vent. People with ls/vtec set-ups please post what you you did in this case. Thanks!!!
Old May 3, 2005 | 08:06 PM
Rod.'s Avatar
Default Re: confused on pcv on ls/vtec....need help (boost fed ls)
endyn catch can system
Old May 3, 2005 | 08:17 PM
Dunc's Avatar
BCICAN
Default Re: confused on pcv on ls/vtec....need help (redturbocivic)
I'll give a for the above. Endyn system is the one I am about to buy....good stuff.
Old May 3, 2005 | 08:25 PM
BoostfedEK4's Avatar
i run 2 catch cans, one for the endyn system and the other for the 2 vents i got welded in on the valve cover.
Old May 4, 2005 | 01:14 AM
Default Re: (BoostfedEK4)
I bought a Greddy catch can about a year ago, I can use this catch can and just buy the fittings to make it work? I just need the fittings for the back of the block and some hose, correct?
Old Jul 12, 2005 | 01:15 AM
b20izzle's Avatar
Default Re: (boost fed ls)
im using a greddy catch can too..wat did u end up doing with ur setup?
Afireinside2285
Dec 14, 2010 07:25 PM
biggdogg
Jun 25, 2003 07:32 PM
sander
Mar 16, 2003 08:23 PM
Ri5e
Mar 23, 2002 05:40 AM
Ri5e
Mar 4, 2002 05:08 AM
