Dumb question sorry
Old Mar 30, 2013 | 05:30 PM
SlowB20z's Avatar
Default Dumb question sorry
i gotta B20z in a 91 DA & my timing belt ribs are sheared off & jumped timing. When it died I tried to start it back up b4 I realized what happened so my.question is did I destroy all the valves in my B20?
Old Mar 30, 2013 | 05:37 PM
1998GsRIntegra's Avatar
Default Re: Dumb question sorry
Who knows. I'd be surprised if you got away with not bending at least a few. Run a compression test or a leak down test and that will tell the tale.
xTyFighterx's Avatar
Only u will know
Old Mar 30, 2013 | 05:45 PM
B_Swapped93's Avatar
either way the head is most likely coming off. post the comp numbers when you can.
Old Mar 30, 2013 | 05:54 PM
SlowB20z's Avatar
thanks guys i will do that
Old Apr 1, 2013 | 11:08 AM
SlowB20z's Avatar
Default Re: Dumb question sorryj
Didnt have my compression tester but did install a old timing belt i had and it will fire for half a sec then die & i assume the valves are bent & not being able to close all the way therefor not being able to build compression
will be checkin cyl pressure with new tester tonite to see if im right
Old Apr 2, 2013 | 07:12 PM
d_moua's Avatar
best get compresssion check.
stan xx
Aug 28, 2015 04:29 PM
Panoply
14
Jun 5, 2012 07:38 AM
lsv0892
Sep 7, 2011 09:56 AM
RockLee`
Oct 29, 2006 03:43 PM
TurboJesse
Sep 23, 2003 06:20 PM
