I need answers...please..
I own an 88 ef hatch.
My problems are:
While driving i will experience backfiring and along with that comes my car will bog down and even as i give it more gas it just doesnt go and it seems like the car is going to die. I can then lightly give it gas and it will creep back to normal.
Also, im blowing white smoke which i suspect to be bad rings. i also hear a bubbling/leaking whilst driving occasionally.
I NEED ANSWERS PLEASEEEEE. Any feedback is beyond appreciated.
My problems are:
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
firstly, is your CEL on? have you checked for codes? have you checked your oil/coolant? have you checked compression?
My CEL is on. due to work I havent been able to check. Though im off tomorrow and planned to do so.
As for the compression im unaware of how to do so. Suggestions? as for oil i blow white smoke and im burning oil not leaking as far as me observing and I account that to most likely being a worn piston ring.
u can rent a compresion tester from an autoparts store and its pretty straight forward. i once had that bubling sound problem before and it was the heater core.
REEMB18C1
22
May 4, 2005 06:34 AM
