Are my piston rings worn?
Old Oct 16, 2002 | 07:10 PM
Andrew 825SM's Avatar
Default Are my piston rings worn?
Did a compression test today after getting my 3mm headgasket (9.0:1?) installed. Numbers were 175, 165, 170, 170. This was on a warm engine, WOT, cranked 7 times and 15A fuse removed. After this, I did a wet compression test. Numbers drastically changed. They were 195, 210, 210, 210. I also checked my oil and it was low....down to the mark and when I start up the car I can see a feint trace of white smoke. After driving, I also see a little trace of wet substance dripping out of my exhaust...wondering what it is? Could it be oil? Im not totally positive on this, but I think its bad piston rings? If it is, do I need to replace them asap cause my car still drives fine. I read somewhere only when the smoke is bluish is when the car is burning oil, but the smoke is white so I'm confused.
[Modified by NHB Fighter, 8:17 PM 10/16/2002]
Old Oct 16, 2002 | 07:13 PM
sutrusu's Avatar
Default Re: Are my piston rings worn? (NHB Fighter)
uhh... a wet substance? is it water? could be your a/c !
Old Oct 16, 2002 | 07:17 PM
Default Re: Are my piston rings worn? (sutrusu)
My a/c was off.
Old Oct 16, 2002 | 07:28 PM
MikeMAN's Avatar
it might be coolant, check your headgasket...
Old Oct 16, 2002 | 08:28 PM
Mr. Softee's Avatar
Default Re: Are my piston rings worn? (MikeMAN)
if you're smoking out the tailpipe, and you're losing lots of oil, witha honda its almost always rings. valve seals barely smoke when they go bad, the only otherthing it could be is your pcv valve...
Old Oct 17, 2002 | 09:07 PM
Cyber ITR's Avatar
Default Re: Are my piston rings worn? (94goldjungsr)
if ur car running too rich does it makes ur oil goes down quickly ?
codyweiss97
Mar 8, 2014 11:04 AM
dc2dragster
Apr 4, 2004 11:16 AM
ILLA_00LS
Jul 22, 2003 12:06 PM
petrv
12
Jul 14, 2003 06:33 AM
Dodger2940
Aug 18, 2002 01:06 AM
